Old 01-17-2018, 08:10 AM
wtribute wtribute is offline
Default [Question] Monitoring vocal while playing track
Please help!
When I record vocal while track in playing, I can hear myself while hitting record botton (Blue circle. see link). Is there anyway to hear or monitor vocal without enabling the blue circle. I'm looking to simply monitor vocal while track is playing without recording. Is this possible with PT? I currently use UA Apollo Twins with PT12
Screenshot is avaiable in the below.
https://drive.google.com/file/d/17UL...ew?usp=sharing
Old 01-17-2018, 08:26 AM
Jason.Thomas84 Jason.Thomas84 is offline
Default Re: [Question] Monitoring vocal while playing track
Following for answer
Sent from my SM-G950U using Tapatalk
J
Win 10, 64 bit, 16gb Memory, Intel i7-7700k CPU, 4.2GHz
Pro Tools 12.8.3
Interface- Focusrite 18i8 2nd Gen
UAD-2 Satellite
Drew Mazurek's Avatar
Enable LLM (low latency monitoring)
PT will now mute the audio being sent to the armed track and you'll monitor through UA's Console app.
See this video.
https://www.youtube.com/watch?v=WTQyPTCAeGc
www.drewmazurek.com
Old 01-18-2018, 08:51 AM
YYR123's Avatar
YYR123 YYR123 is offline
I believe Drew's answer is the best answer for you, using Universal Audio's console application.
But.....for those that are not using Universal Audio Interfaces "and" are monitoring the thread.
The button directly to the Right of the "Track" Record button, the one that has a capitol I. That is the input monitoring button. This will allow you to hear the microphone or whatever is connected to that track without recording.
You can also search the PT Reference Guide for "Input Monitoring" .
Cheers.
Oh yeah and I did not see a Green Circle anywhere.....
Daniel
Old 01-18-2018, 11:10 AM
K Roche's Avatar
K Roche K Roche is offline
The other way would be to engage input monitoring. the little button with the (I) the one next to the record button
System :
Avid HD Omni I/O Interface ...Mid 2010 Mac Pro/ processor- 3.33 6-core Intel Xeon "Westmere" w/ Memory- 24 GB........PTHDN 2018.12 on OS 10.13.6 High Sierra on primary boot drive (SSD PCIe 512 GB Samsung SM951) FCPX files storage on Apple 1TB HDD and PT sessions storage on Apple 2TB HDD--
"Peace cannot be kept by force. It can only be achieved by understanding" Albert Einstein
Enjoy the Journey
.... Kev...
Old 01-21-2018, 10:56 PM
See this video.
Thanks for the tip. The problem with doing that for me is I can't monitor Echoboy plugin on the UA console.
Old 01-21-2018, 11:08 PM
Cheers.
Great, now I know what [I] is for. Thank you!
Once the take is recorded, is it possible to have [I] turned on and still listen to the recorded vocal?
With [I] turned on, I would have to disable [I] every time when I have to go back and listen to the recorded vocal.
About the green circle, Sorry! the color used was blue.
Old 01-21-2018, 11:23 PM
See this video.
Thanks for the tip. The problem with doing that for me is I can't monitor Echoboy plugin (PT) on the UA console.
I tried below but unable to output vocal track (w/Echoboy) to UA console.
Track muted on PT and Unmute on UA console. LLM is also turned on.
https://youtu.be/WTQyPTCAeGc?t=8m19s
Old 01-22-2018, 02:46 AM
BScout BScout is offline
No, you cannot simultaneously listen to input and the track recorded at the same time. You can, however, put it in other modes such as:
  1. Disable input when dropping out of record (this is the default setup) so that you can hear what you recorded after you stop recording.
  2. Listen to the previously recorded track until you put it into record (at which point you are hearing the new recording.) This is how quick-punch mode works but you can do this with other recording scenarios too.
Old 01-22-2018, 05:05 AM
It's either or.
www.drewmazurek.com
How do I play to a track without recording it? rickwin7prt8 Pro Tools M-Powered (Win) 1 08-24-2010 01:08 AM
Recording and getting latency when play back the rec track willl3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 02-25-2008 01:22 PM
recording and play midi track hfd5 MIDI 7 10-23-2007 09:03 PM
Can you play along with a track without recording? newathis Tips & Tricks 5 01-16-2004 08:56 PM
Can i Play one track while recording another? calmlikeabom General Discussion 8 08-23-2002 09:25 AM
