Old 08-02-2013, 05:44 AM
hollow hollow is offline
Default Eleven rack interface slow lags
Just got myself a second eleven rack for my other studio a few weeks ago.
I've had a problem with the interface/display lagging terribly all the time.
For example - if I switch a preset with the scroll - the preset name switches instantly - but the amp and other parameters takes 3-4 seconds Before it switches.
This also happens with all the other switches on the front panel - edit, save etc... all the buttons takes around 3-5 seconds Before it reacts...
latest firmware, hooked up via spdif to Another interface...
Old 08-02-2013, 05:51 AM
Default Re: Eleven rack interface slow lags
I just found out that after a few restarts - if I'm lucky - it works normally again.
Now I just restarted the unit 3 times - and now Everything reacts as normal...
what could this be? software or hardware related?
Old 08-02-2013, 06:49 AM
sunburst79 sunburst79 is offline
I can't say as I only have one to test with. I would tend to think restarting the 11R unit shouldn't really make much difference. Although its possible the something in PT is considering one unit a primary and one unit secondary and restarting the unit somehow jogs that or resets something.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 08-03-2013, 03:36 AM
zedhed's Avatar
zedhed zedhed is offline
latest firmware, hooked up via spdif to Another interface... ???
Latest 11R Driver installed? (released June 2013)
What interface is the 11R s/pdif to?
When you open Pro Tools check to see which interface is chosen as Playback Engine & ascertain whether or not the same one is chosen each time.
Too much blood in my drugstream
Gigabyte X99 SOC Force Mobo Bios vF6d
Intel Core i7 5930k socket 2011 v3 @ 3.50GHz
32GB DDR4 Crucial RAM
System: Samsung M.2NVME SSD 960 Evo
Record: Samsung M.2NVME SSD 960 Evo
Samples: Samsung SATAlll SSD 840 Pro
Storage: 2x Samsung SATAlll SSD 840 Pro
EVGA GeForce GTX 750 Graphics
PT 11HD (v11.2.1) Omni s/pdif w Eleven Rack
HD 96I/O
Win 8.1 Pro
Old 08-08-2017, 02:36 PM
Hey all!
I'm digging up this thread again.
still have the same 11r - still loving it - but I still have this problem.
it doesn't happen all the time... like yesterday I had this problem no matter how many times I restarted the unit.
Today I fired it up - no problem at all.
I can see that when it is booting up - the marker that is flying across the screen at the bottom - if that one is moving slowly - I know I'm gonna have the error.
It is not affecting the sound at all - it is just that everything on the display is really slow - If I move a knob - the changes happens like two seconds later.
there is like a two second lag to every action - even the delay tap led is lagging...
PS - the unit is NOT connected to my computer - pure stand alone
anyone else seen this?
Old 12-12-2017, 03:07 AM
bump - anyone?
Old 12-12-2017, 08:54 AM
panamajack's Avatar
panamajack panamajack is offline
Four years + and no problems? Or intermittent? Or chronic?
No indication of your computer, operating system (version), or your DAW. Might consider providing that information...or even whether or not you are filtering/isolating your electrical current.
PT10.3.10HD(Tyan s2932 [8core Shanghai 2.7GHZ] 32GB,Win7 SP1); PT10HD(Tyan s2892 w/10GB, Win7 SP1);PT8HD(Dell 690 quad Xeon 3.0, 8GB, Win7,192 I/O, 96 I/O);MacBook Pro: 11R, Apogee Element 46, Focusrite 8PreX PT HD 11.3.2; Mac Pro 3.47 Hex 32GB, OSX 10.12.6/L10.4.2;L9.1.8, 2.64TB; G5 D2.3 4GB, 10.4.11/L8; 12c MP 2.66/32GB PT12.4; Structure, GigaGS3, Kontakt 5, Garratin, Sibelius 8.7+, Finale26,EMU,Vegas Pro 16-10/; RME HDSP9652,MOTU 2408 MKIII/1224/308, FX,Kurz,L5s,Strat,ASAT,JB,Zon
Old 12-12-2017, 09:46 AM
junkgear's Avatar
junkgear junkgear is offline
Never had that issue, but it is most likely a hardware problem that is affecting the software. A lot of intermittent problems happen when either the unit is powered on cold or likewise when it gets warm. You might want to pay attention to the conditions of the unit when you do encounter the problem and maybe that will help you track it down. Unfortunately a hardware issue would most likely mean sending it out to have it serviced.
Will K
System Details
Old 01-22-2018, 07:42 AM
yeah as you say this is likely a hardware issue...
this is mostly happening when I'm starting it up - if I'm rebooting the unit repeatedly it will act as normal on say... the 5th och 6th attempt...
It is sitting by itself in 4 space rack so heat is not a problem.
wonder is there is anyone serving these units anymore...
Old 01-24-2018, 02:21 AM
I have opened up the unit but I cannot see anything that would be out of the ordinary...
yesterday I restarted the unit probably 25 times - only one time could I get it to boot and work properly.
Note that - the unit is sounding as it should all the time. The way I notice this is that when I'm booting the unit, the little marker flying from left to right is doing this in "slo-mo"
and when I reach the interface everything has a 2-3 second lag... even the tap tempo is blinking in slo-mo. If I change preset the name is changing but all the parameters are 2 seconds behind.
what would you guys look for?
Eleven Rack as mixing interface? Allbaldo Eleven Rack 17 10-16-2013 09:52 PM
Eleven Rack as Interface Dopamine Pro Tools Software (Mac) 10 02-03-2013 12:35 AM
Eleven rack with another interface ? oplatner Eleven Rack 11 05-30-2012 08:33 AM
Eleven Rack vs. Eleven Rack to another interface petesteen Eleven Rack 1 02-05-2012 03:53 PM
Eleven Rack + Another interface? Kaigne 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 12-01-2009 07:49 PM
