Will Control 24 work with USB to ethernet adapter ?
My contorl was working with the ethernet port of the mac.The ports blew.We change to a USB to ethernet adapter which logs on to the net perfectly. when plug to the Control24 and try to enable the control 24 an ethernet connection error occours. I'm Using PT 8 with OS 10.5.8
SB |
Re: Will Control 24 work with USB to ethernet adapter ?
I am presently using a USB to Ethernet adapter to connect my Control 24 to my G5. It works great. I had issues with it not wanting to connect via ethernet for some reason and switched with no problem. I'm using a Linksys adapter.
Good Luck. Gary Kesling www.9livesrecords.com www.2catstudios.com www.2cattunes.com |
Which version of os x are you running?
SB |
I am running Leopard and Protools HD 8
USB-Ethernet adapter | andreasaidu | Artist Series | 6 | 02-18-2011 09:16 AM |
USB to Ethernet Adapter with Euphonix mcmix | gsilbers | Artist Series | 3 | 05-04-2010 10:57 AM |
Control 24 w/ USB->Ethernet adapter? | The Chinese | Pro Tools TDM Systems (Mac) | 3 | 04-23-2009 11:55 AM |
USB to ethernet adapter | Craig F | ICON & C|24 | 10 | 12-18-2007 11:11 AM |
Procontrol, USB to ethernet Adapter | spigots | ProControl, Control|24, Command|8 | 4 | 02-21-2003 04:49 PM |
