Old 04-10-2004, 10:02 AM
Echo studios Echo studios is offline
Default Control|24 losing Ethernet connection
Hey all,
I've been experiencing some Ethernet connection problems using the C|24 for long sessions.
Sometimes, when mixing and using the board functions a lot, the session goes into an endless audio loop so i have to STOP and then the C24 lights freezes for a few seconds and then the board goes OFFLINE..
After that an error msg appears in PT saying " Could not establish Ethernet Conncetion - PLease power down and restart the Control24, etc etc".
So i have to go into the setup/peripherals menu and the uncheck and then check back the 10/100mbits integrated network controller in order to rescan the ethernet port, select my C24 and then re-enter the session to continue my work.
This seems to happens more often when i'm using a lot of RTAS instances, big sessions or that my CPU usage is set at more than 80% in PT.
My system is as follows:
PT|24 MIX+
Intel P4 2.52ghz
ASUS PC4800-E Motherboard with integrated network controller.
1GB DDR
(4) 10KRPM Cheetah's hooked on Adaptec UW controller.
Anyone having these kind of issues..?
1. Is that a C|24 hardware problem/failure?
2. A bad Ethernet cable? (It was bought direct from Digi)
3. A slow computer...(!)? or too much CPU usage?
Thanks for any inputs,
-Dan D.
PT HDX2 / Ultimate / D-Command ES 24
MP Dual 3.66mhz ( 6-Cores) / 128GB / SDD 8TB
OSX Sonoma 14.4
Dan Desilets
Mix/Mastering Engineer, Guitarist, Composer
New Website live @ www.yuccamusic.ca
Old 04-12-2004, 04:17 PM
Sean Halley Sean Halley is offline
Default Re: Control|24 losing Ethernet connection
The ethernet jack on my G5 didn't hold the connector very tightly, and I got those messages all the time. I taped the jack tight to the chassis of the CPU so it wouldn't move, and now I don't have that problem. The next time you get the message, try pushing the cable firmly into the jack of the CPU, and see what happens....
S..
"it's not about making the changes, it's about playing ideas in time"
Scofield...
MC Control losing connection Trazan Artist Series 7 07-27-2012 04:57 AM
Control 24 losing connection KrisHeinold ICON & C|24 4 12-06-2010 11:22 AM
Control|24 losing Ethernet connection on TDM/XP Echo studios Pro Tools TDM Systems (Win) 2 04-10-2004 08:07 PM
control 24 losing connection w PT firedog57 ICON & C|24 3 02-02-2004 08:23 AM
control 24 and ethernet connection ianmiller ICON & C|24 3 03-02-2002 11:24 AM
