DAE error 2 was encountered?!?
I have tried searching the DUC and Answerbase to no avail... can anyone tell me what's happening?
When launching existing sessions, I get this error message on start-up. I'm using PT LE 5.2 on a 400MHz iMac with a mBox. I have done SEVERAL sessions up til now and had no problem going back to them. I have trashed all the prefs and reset my settings.... ANYONE!?!?
iMac 27" 3.4GHz 28GB RAM OS X 10.9.2 / PT11.1.1 2 large cups of coffee AM / 2 Stone IPA PM |
Re: DAE error 2 was encountered?!?
Can you launch Pro Tools and open session(s) using the File>Open Session without causing the error?
In the meantime, increase the Preferred memory size of the Pro Tools and DAE applications. Increase the DAE Preferred size to 80000k (80MB) and Pro Tools to 70000k (70MB). Never change the Minimum memory size. If you have, you can set it back to the default setting by typing a 0 into the field and press Enter on the numerical keypad. Brent |
Brent-
I just tried several times to open the session(s) from the file menu to no avail. I already had the memory settings as you recommended, but I reset them just in case. Still the same error, this time it says "Could not complete command "Open File" because DAE error 2 was encountered" Thanks a lot for your help!!
Check the integrity of your drives with Disk Warrior or any other such utility. Repair any and all corrupted catalogs and/or BTree Directories.
Brent |
HELP DAE-error __ was encountered | helmer | Windows | 2 | 10-23-2013 02:56 PM |
DAE error 720 was encountered | Labbe de Montais | Pro Tools SE and Essential (Mac) | 5 | 05-06-2013 06:48 PM |
DAE error -4 was encountered | Nils Groth | Pro Tools TDM Systems (Mac) | 4 | 03-17-2009 05:20 PM |
DAE error -199 encountered | ripe | Pro Tools TDM Systems (Mac) | 1 | 01-25-2002 06:39 PM |
DAE error was encountered while trying to connect (error #-7101 | Enis Presheva Jr. | Pro Tools TDM Systems (Mac) | 1 | 06-07-2001 12:45 AM |
