Another "11R for live use" thread :)
Hi everybody!
I'm planning to start playing live again and I'd like to use my 11R instead of my old amp (weight reasons mostly). I have some questions regarding 11R for live performances: 1. I'd like to go direct to the PA. What's best in your experience: using the PA monitors for listening to my guitar in the mix or having a dedicated active FRFR cab to monitor guitar exclusively? 2. If I need a FRFR cab, which is the best bang for the buck? 3. Is the lack of spillover very noticeable in live situations? If it is, I've got a g-major hanging around that I can use to address this problem: which is the best way to connect it to the 11R (11R's loop is not an option I suppose)? Thanks in advance. P.S. I wrote this post in other forums too to learn from more experiences possibile. Hope this won't upset you. |
Re: Another "11R for live use" thread :)
I use my 11R live almost all the time. I also go Direct to FOH and just use the monitors to....monitor. Here is the Kicker though: I'm a Bass player so I don't have a lot of different things going on all the time. I may use a little Chorus, maybe a little overdrive, and occasionally, a little Flange. I set up all my "tones" on the 11R and usually have the mixer EQ set pretty flat.
My Guitar player also runs Direct to FOH, use the monitors like I do. For some reason though, he likes the low-mid and hi-mid boosted somewhat on the mixer. He can achieve the same thing by tweaking the 11R but he does what he does. We are a 3 piece Blues/Rock band but shy away from really Heavy Metal stuff (we be old folk also). So, we don't get into a lot of distorted guitar, growling vocal stuff. FRFR's are something we don't worry about. If for some reason we want something for monitoring other than the regular monitors we use, we just bring amps. It also would defeat the purpose of a quieter stage and less gear to move. Not saying to NOT get an FRFR, just don't need to do redundant setups. About the only time we actually do have amps on stage is when we are not using OUR PA and the one provided just isn't up to par. In the end though, it is all in what sounds best to you. Hope this is helpful. |
It's VERY helpful!
Thanks for your advice Wpawley. |
Small world (!!!) but I will reply here also ;-)
Going direct and I use one of the band powered speaker for monitor (Yorkville NX55P) or I bring my EV ZLX12P (best bang for the buck). We never bring amps anymore. |
P.S. 11R users' world is a small one :) |
Mac i5 2012 "Bus Error" in thread "Main Thread", at address 0x0 | tony20970 | macOS | 2 | 01-29-2014 10:45 PM |
"segmentation fault" in thread "Main Thread" , at adress 0x0 | melvindesk | Tips & Tricks | 0 | 06-13-2012 06:17 PM |
Pro tools 9 crashes at startup "Bus error" in thread "MainThread", at address 0x0 | danball | macOS | 2 | 09-26-2011 04:49 PM |
"Segmentation Fault" in thread"Main Thread" at address 0x0 | refuu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-13-2011 05:18 AM |
PT9 Session Troubles - "Bus Error" in "Main Thread" & Could not complete the Open... | tohmit | macOS | 5 | 03-23-2011 12:13 PM |
