Old 05-20-2008, 08:59 PM
Jeff E Jeff E is offline
Default Muting channel and the SENDS...
How can I link the Channel Mute so that when I mute it, it mutes the SENDS... too?
My mistake.. THis should be the sends and not the AUX
Thanks..
Jeff
Old 05-20-2008, 09:49 PM
Craig F Craig F is offline
Default Re: Muting channel and the Aux...
deselect the PRE button from the fader/pan window
Thank you,
Craig
Old 05-20-2008, 10:08 PM
RobMacki RobMacki is offline
That will work if want to mix Post Fader.
If you want to mix Pre Fader you can select your group with Aux and change Globals so only Mute is linked if you wish.
hth
Old 05-21-2008, 07:53 AM
Thanks I will give that a try...
Jeff
Old 05-21-2008, 08:14 AM
Default Re: Muting channel and the SENDS...
OK, I think I am missing something...
I am in Prefader on the SEND (Not the AUX).. and I set up a group and have it follow global and have chosen the sends (all of them) to Follow MUTE.
When I mute the vocal track, it does not mute the send.
What I am trying to do is take BGV tracks out as we track so the singer doesn't have to hear them in the headphones. I have the head phone mix in aux track. On my consule I used to be able to mute the track and mute the AUX at the same time. Id rather not have to make 3 mouse clicks to do this....
THanks
Jeff
Old 05-21-2008, 09:05 AM
BaileyBass BaileyBass is offline
E.
Jeff
Are you checking with your eyes or ears? As i remember, when the send mutes it does not show muted, although it is. I will confirm when i get back to the dungeon, SB
Old 05-21-2008, 09:09 AM
Yeah I am watching the meter.. and hear it in the phones.. I am trying to get this figured out before the session start...
Thanks..
Right now I have it down to 2 clicks.. Mute channel and mute send.. but one would be great..
I know if the send is in post fader its fine but then I lose the ability to create a head phone mix...
Jeff
Old 05-21-2008, 10:30 AM
Thanks..
Jeff
Jeff, got home and mine mutes pre/post. Are you sure that you have the send in the same slot as that selected in the globals, in the "modify groups" window? Seems to all work as it should here. good luck SB
Old 05-21-2008, 10:48 AM
Yes.. Looks like this unless I am missing something...
Channel Pic
Old 05-21-2008, 10:59 AM
Stig Eliassen's Avatar
What if you un-check " Follow Globals ", and set this up under " Attributes " instead? I remember having some initial problems with FG, so I stopped using this setting.
Channel Muting in Snapshots Footy VENUE Live Sound Systems 2 12-05-2012 11:28 AM
Muting channel when punching in? RKrizman Pro Tools TDM Systems (Mac) 25 08-09-2010 01:11 PM
Sends View Help! (w/ and w/o fader in channel) kirkbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-22-2009 07:12 PM
Saving a channel strip with comp, eq, sends ect. Jakob Clemen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-25-2006 08:27 AM
Why isn't there a level control on channel sends? rune_sm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-02-2004 04:10 PM
