Old 08-22-2006, 10:27 AM
msg6794 msg6794 is offline
Default volume attenuator
i just recently upgraded to event precision 8's. before that i had some smaller m-audio studiophiles. to get from the m-box (1) to the speakers, i had this 1/8" stereo -> 2x 1/4" mono cable that i ran from the front headphone jack to the speakers. it worked great for me, since it provided a built-in volume control. when i needed to go to headphones, i just unplugged the monitors, and put the cans in the same output. messy, but it worked.
now, with the asp 8's, i'm trying to do it the "right way". i got 2 monster cable 1/4" -> xlr cables and am running them out of the line outputs on the back of the m-box. however, now i'm sorta stuck with my volume in monitoring. i can use the "mix" knob to attenuate the overall volume, but it adds noise if i have an input turned up, and it makes it harder to use the mix knob properly anyway, since if it's at 100% playback, the volume is LOUD!
every studio i've been in has a separate hardware volume knob for the monitors. can someone recommend a good one to pick up? it would also ideally have a "mute/bypass" on it, so that when i use headphones for an overdub, i don't have to turn off the monitors each time.
or is there a simpler way to do this that i'm overlooking? sorry for the lengthy post, and thanks in advance!
003 Rack | Dell Studio XPS 8700 (Core i7 4790, 16GB RAM) | Windows 10 64-bit / PT 12.6
Old 08-22-2006, 10:58 AM
Default Re: volume attenuator
just saw another post reference the mackie big knob, of course. that might be perfect. anyone here use it?
Old 08-22-2006, 11:14 AM
Matt Whritenour Matt Whritenour is offline
I like the Presonus Central Station better
http://www.sweetwater.com/store/detail/CentralStat/
and if you get it before august 31st you get the remote for free which is great to have
www.klarityrecordingstudios.com
Old 08-22-2006, 11:43 AM
I have and use the Mackie Big Knob. It does what it is supposed to do and sounds like a perfect solution to what the poster is asking. Having that Big Knob always nearby is very convenient for me. The Presonus Central Station cost a little more but does more and is rack mounted which helps to keep cable clutter off your desk. The free $149.00 remote is a must have.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 08-22-2006, 11:51 AM
thanks for the replies! i'm reading up on both of these, and they both seem great. the big knob seems to do what i want, though i like the rackspace/remote setup of the presonus, since it takes up less desk space... but it's also $200 more. guess it's off to GC to try them out if i can!
Old 08-22-2006, 02:00 PM
JMS40 JMS40 is offline
Here's another option I've read positive reports about.
www.sweetwater.com/store/detail/CControl/
Old 08-22-2006, 10:03 PM
you don't want the c control
I had it, and it's not that good.
it does what it's supposed to, but I think it added some distortion to the signal because my ears used to get fatigued quickly when working then after i got the central station I immediatly noticed a difernce working with it
and the remote is a great feature
Old 08-23-2006, 08:37 AM
i picked up the big knob last night - so far it's great! it's exactly what i needed. there was a little bit of hum, but it went away when i set the inputs and outputs on the BK to -10db instead of +4db... kind of odd, but it works! shouldn't the mbox and my precision 8's both run at +4?
in a related question - does anyone know if it matters if i use balanced or unbalanced cables getting from the mbox to the BK? i'm using unbalanced there right now, since the GC sales guy said i should use them... but i thought balanced was a better option for this. (i'm using balanced 1/4" -> XLR to get from the BK to the monitors.)
Old 08-26-2006, 01:59 PM
this has gotten sorta OT, and i apologize, but i still would like to know about the connections from the mbox to the big knob here... anyone?
Old 08-26-2006, 02:47 PM
you should deffinatly use balanced
then you'll also be able to set those switches back to +4
FA: THD Hot Plate 2 Ohm Amp Attenuator joepopp Buy & Sell 0 02-11-2014 09:11 AM
power attenuator ggmmss 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-07-2006 04:57 PM
Goldpoint attenuator anybody? Lalaman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 10-27-2004 12:12 AM
5.1 surround sound attenuator poldo Pro Tools TDM Systems (Mac) 3 07-04-2002 02:18 AM
Attenuator 888-Genelec joy4u Tips & Tricks 1 03-08-2001 10:56 AM
