diff between \"Gain\" and \"Normalize\" in Audiosuite
Can anyone tell me the differences between the 2?
Here's how I see it: With Normalize, you're limited to the highest audio peak. The plugin will bring all audio levels up, relative to the highest peak. Once the peak hits the "ceiling", the plugin won't go any further. With Gain, it looks like it will just keep boosting levels until, in practice, you could have one big fat waveform. By that time, most everyting would be unintelligble, of course. So, Gain is Absolute, while Nornalize is Relative? Gain looks like it's more flexible, since you can lower levels, as well as raise them. What am I missing here? Thanks |
Re: diff between \"Gain\" and \"Normalize\" in Audiosu
Thanks. That's helpful info.
Re: diff between \"Gain\" and \"Normalize\" in Audiosuite
Normalize is the same as Gain. The difference is;
*Gain will increase the level by the amount decided by the slider *Normalize first analyzes the entire region/s for the maximum peak reached. Then, depending on the Max Peak level you have set, it will raise the level of the entire region to such that the max peak of the resulting region does not exceed the value entered. Example: Maximum Peak of a region is analyzed at -8 by the Normalize AudioSuite The Value entered in the Max Peak Box of the plugin is -1 The plugin will gain the region levels by 7db so that the maximum peak of the resulting region is -1 |
Thanks for the reply. Makes sense to me.
AudioSuite Gain/Normalize also on Clip Gain | A-n-d-i | macOS | 0 | 03-13-2014 12:46 PM |
Gain and Normalize | French links | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-20-2006 06:21 PM |
Gain and Normalize | French links | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-17-2006 04:34 PM |
Normalize vs gain (Audiosuite) | jake9n | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-27-2004 09:27 PM |
Normalize vs Gain | Maltin | Tips & Tricks | 16 | 11-14-2000 04:35 AM |
