Old 09-08-2014, 11:19 AM
jssamsara jssamsara is offline
Default No sound from click track
I've tried everything.... but I just can't get the click sound to happen any longer... did a fresh install of windows 8.1 .... protools 10hd... it wokred a few days ago on the old installl but now nothing... PLEASE HELP!!
Old 09-11-2014, 04:03 AM
stickboymusic stickboymusic is offline
Default Re: No sound from click track
Click the triangle in the circle in the top right hand corner and make sure "show midi controls" is ticked
Now in the midi control box that appears - make sure the small picture of the metronome is highlighted
Old 10-18-2014, 06:50 PM
motorola motorola is offline
I have the same problem have you resolved it
Old 10-18-2014, 07:09 PM
Had a tough time finding this, a post in 2010 helped me
Click Count off was set to play only selected play and record solved problem for me
Hope this helps someone else
Old 02-28-2015, 11:05 AM
davidskick davidskick is offline
on the TRANSPORT display.. ENABLE the CLICK/METRONOME (if grayed out).. I had the same issue and drove me nuts until I figure this out... hope this helps
Mac Pro Desktop Quad Core w/64G of DDR3 ECC memory & Sonet Expansion Chasis for PT 2018.12.0 HDX Card in conjunction with Burl Mothership & converters - C24 Console
Old 05-05-2020, 06:42 PM
tomfarleymusic tomfarleymusic is offline
Yes @motorola had it right. If you think you've tried everything, go to Click/Countoff settings and change the click settings to "During play and record." When I was on "Only during countoff," it wouldn't go. Useful solution!
Old 02-28-2022, 06:41 AM
WenxuanLiu WenxuanLiu is offline
Thank you a lot on, the Click/Count Off setting is a right solution for me!
Old 07-25-2022, 05:08 PM
Bradford Cox Bradford Cox is offline
I had the same problem with a client's file. No click during playback and they wanted me to tighten up vocals to the click.
The fix:
Display the transport - either CMD kp1 or across the top of the edit window
Double click on the Metronome icon (or pulldowns: SETUP > Click/Countoff)
Brings up a window
Select "During Play & Record"
Ok
Done
Old 07-10-2023, 09:07 PM
tothrec2 tothrec2 is offline
Thanks! I'd almost run out of hair to pull out!
(I'd been messing around with that setting and forgot)
How to change click track sound? Mike Borok 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 02-12-2015 09:38 AM
No click sound on click track sighermike Pro Tools M-Powered (Mac) 3 10-10-2012 12:01 PM
Cannot get click track to sound in ProTools 8 Blakemusic1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-25-2009 03:22 PM
Missing Click track sound bookerfatz2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-20-2008 02:37 AM
Customizing Click Track Sound in 6.1 LE D Allen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-18-2004 08:28 PM
