Old 05-23-2019, 06:05 AM
jamesleonard jamesleonard is offline
Default Can one midi or instrument track, trigger, multiple instrument tracks simultaneously?
Hello,
Is there a way I can have one midi track or one instrument track, trigger/control five instruments tracks simultaneously on Pro Tools? Because I can trigger one track at-a-time (no problem), but not two or three, etc.
Lets say I have FIVE different instruments instantiated in Pro Tools - in FIVE different tracks. When I route the Midi channel (on an instrument track or midi track), I can only control one instrument-at-time - because of the options. For example: inst 1; inst 2; inst 3; inst 4; inst 5, ARE LISTED - but, I can only pick one of ‘these’ - and what I want to do is to trigger all FIVE at once! (good for parallel motion and- the-like!)
You can implement this feature on Ableton (on a trigger track) - but can it be done in Pro Tools.
Obviously, this method is easier - whilst EDITING - because you only have to edit the ONE track - instead of FIVE!
Is there something in the midi configuration i’m missing here somewhere?
Thanks
Old 05-23-2019, 06:43 AM
ChuckS ChuckS is offline
Default Re: Can one midi or instrument track, trigger, multiple instrument tracks simultaneou
On the Mac Control-click on the MIDI output assignment to add additional outputs. For Windows I think Start-click (Win-click).
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
Old 05-23-2019, 07:38 AM
philgrab philgrab is offline
Yes. Read up on midi channels. You just assign the midi track to the channels you want fed. Then make sure the VST or AAX instrument is on that channel. I put strings swells behind piano parts in Protools as well as multi instrument parts and use a single midi track to control them all. Helps to load all the instruments first then the instruments should show up in the channel view.
Old 05-23-2019, 07:42 AM
Thanks ChuckS - that's what I wanted.
Old 05-23-2019, 07:47 AM
Thanks Phil.
Old 05-24-2019, 07:33 AM
Ben Jenssen's Avatar
This goes for track outputs and sends too: ctrl-click (mac) an output or send to send to additional destinations. Very useful.
MIDI to trigger Instrument Tracks without pressing Record on/off Electronic1982 Pro Tools 12 1 05-14-2017 05:09 PM
Midi track will not trigger Reason instrument Mark Hucks Pro Tools 12 3 04-23-2017 01:57 PM
Recording multiple Midi (instrument tracks) Bookerv12 Getting Started 9 02-08-2014 06:17 AM
Multiple MIDI Tracks controlling one Instrument Track's MIDI daniel.yengle Tips & Tricks 3 05-04-2011 03:27 AM
How do i track multiple midi tracks simultaneously? Bambison Pro Tools TDM Systems (Mac) 1 11-04-2009 02:14 PM
