  #21
Old 01-02-2015, 09:25 AM
Jay_uk Jay_uk is offline
Default Re: Using ANY midicontroller as plugin controller in PT
Originally Posted by marlasmusic View Post
Just wondering if JAY UK ever came up with a solution. Did the update work? I own the same Axiom Pro with hypercontrol. Did the link for the update to the Air model work?
No it did not work, sorry for not posting a reply.
All i know is that the Axiom pro is working with full Hypercontrol on Windows but not Mac. ….. go figure.
  #22
Old 05-29-2016, 05:19 PM
GovrCheeze GovrCheeze is offline
Default Novation nocturn working to control aax
Open Automap Server, go to Software Setup tab and click Advanced. Set the Midi ports to be Automap MIDI. Select Midi Channels 1-8 (you might not need all, I just assumed it might cause less clashes). Disable HUI. On the Nocturn, make sure your 'USER' button is lit up. Open the Software Mapping Editor. Assign the MIDI CC's listed a few pages ago for Plugin Cycle/Select, Etc. Save a profile. Open Pro-Tools 11 or higher (I'm using 12.4). In Peripherals set up a MIDI controller w/ the M-Audio preset and MIDI I/O assigned to Automap MIDI Ch 1.
As he said before, select a track, use whatever you assigned to Plugin Cycle to choose between plugins, use whatever you assigned to Plugin Select and your Nocturn will switch to being assigned to all the controls in the plugin! WEEEEE!
Thank you so much for posting this! My Nocturn was collecting dust but NO MORE!
  #23
Old 11-22-2017, 02:30 AM
Sir Hannes Sir Hannes is offline
Is this useful with AudioSuite plugins as well? (i am mostly working only with that!)
thx
nanokontrol2 and pro tools express hotpies Third Party Interfaces 1 09-03-2014 10:40 AM
Korg nanoKONTROL2 David2934 Eleven Rack 0 01-03-2013 12:58 AM
Pro Tools 10 with Korg NanoKontrol2...? Vaernima Windows 5 02-23-2012 04:34 AM
korg m3m with pte eddie lamb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-24-2007 12:00 AM
Pt and the korg er-1 (anyone?) Ssaidvox1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-11-2001 07:12 PM
