Re: copy multiple cut locations to a region right below
Fantastic. I'll be using this a lot! Thanks man.
Just out of interest - has Grid > Clips/Markers always been there or is this something relatively new? I don't remember seeing it before. It would be handy if there was an Edit Menu>Seperate Clip>On Markers command and multiple marker lists per session.... Or even a generate markers from selected clips command.
Dave Marsden UK |
As long as the markers are at a clip boundary, they do no harm, obviously. Another way of working in the future : "alternative markers", an audio track with an empty clip group (containing nothing) of the entire length of the session, can be cut according to the mic-track-clips and labeled (e.g. with notes about pitch or whatever). That alternative-marker-track can be hidden and thus can not interfere with the separate-on-grid-command.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
Great. I got a heads-up on this function here on the Duc some time ago.
You may vote for : http://protools.ideascale.com/a/idea-v2/97504 http://protools.ideascale.com/a/idea-v2/174438
Yeah, I tried it with hiding the whole marker ruler. Doesn't work as you already mentioned.
Another thing I came across in my session worthy to point out are sync points. E.g. generated by using beat detective. There will be also cuts made on those. So before going thru the whole process one should make sure all sync points are removed by selecting the regions and go to Clip -> Remove Sync Point. However, thanks a lot Joachim! This will make my life much easier by now! |
My pleasure !
#16
Dave Marsden UK |
#17
As far as I remember, it's been there since about PT5-ish (maybe longer, but I didn't come back to using PT in anger until about v5). Quote:
Have you tried simply hiding every track, other than the one you want to use as a guide for the grid, and the one you want sliced on the corresponding grid? ( of course, create a Memory Location with track show/hide properties first). As for other marker lanes, until that finally gets implemented, I use several tracks of the aforementioned dummy regions / region groups on a MIDI track. Sent from my iPhone using Tapatalk |
#18
Dave Marsden UK |
#19
It's less hassle than it might initially seem, just create a memory location for your default track view (no doubt you are aware that you can set the properties of a memory location, so that it is neither a market, nor an edit selection, but simply shows / hides any configuration of tracks you wish). Create any number of memory locations for the other track views you want (hide all tracks except VCA's / show only drum tracks and corresponding Auxes etc etc). I have these memory locations saved as part of my templates (some of which are pretty large, and complex), and it can really speed things up, especially when combined with window configurations. For example, I want my default track view : .1. I want to see just VCA's and the master track : .2. Back to my default view : .1. As you can see, you can really fly around the session, and of course add to, or modify the memory locations as needs be. Sent from my iPhone using Tapatalk |
#20
That wouldn't work for me unfortunately. I've been down this road before of saving what tracks are hidden or shown into memory locations and they way I work meant I was constantly having to update the default tracks view. The same applied to saving Window Configurations into memory locations.
Dave Marsden UK |
Edit multiple memory locations at once? | helenvee | Pro Tools 12 | 1 | 05-08-2017 11:28 AM |
Copy region in grid | Schaul | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-31-2010 02:45 AM |
Midi region copy | Mr.O | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-03-2009 04:41 PM |
Deleting multiple memory locations quickly? | amundsen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-01-2004 11:12 PM |
Lost region locations! | snapple | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-11-2002 06:20 AM |
