Old 09-25-2016, 12:11 PM
wevets wevets is offline
Default User-defined keyboard shortcuts
I'm looking for a way to define a few shortcuts for editing ops that I use a lot but for which Pro Tools offers no pre-defined shortcut.. Pro Tools doesn't seem to offer a way to define my own shortcuts.
Is there something I'm missing in Pro Tools? Is there a reliable 3rd-party package that lets me define keyboard macros that can be used with Pro Tools.
If it helps, I want to use Ctrl+Alt+V, requiring both hands, through a shortcut I want to define that will use only one finger. It would even be nice to be able to override a Pro Tools pre-defined shortcut that I never use, but this is probably asking too much.
Any one have any help here?
Old 09-25-2016, 01:28 PM
Shan's Avatar
Shan Shan is offline
Default Re: User-defined keyboard shortcuts
Use AutoHotkey.
Code:
#IfWinActive ahk_class DigiAppWndClass
t::
WinMenuSelectItem, Pro Tools, , Edit, Paste Special, Repeat to Fill Selection
Return
"t" in the above example will be your newly assignable key to that specific command. Change it to taste. Hope that helps.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 09-25-2016, 08:16 PM
Thanks. I'll try it out shortly.
Old 09-26-2016, 05:17 AM
joachim's Avatar
joachim joachim is offline
Another option for 2-hand shortcuts : get a programmable extra keyboard (I use the Expertkeys EK-128) and assign those shortcuts to a single button.
The code given is the "seed" example to assign commands, that are menue items only, to a self-defined shortcut.
Like all the "cut/copy/clear / all/pan/plugin" -commands.
The hard thing is to know, which shortcuts are already taken by PT itself. Took me 3 days to make a list ... .
You can override the PT shortcuts. But overriding single key commands like "q" will result in not being able to use the letter "q" when naming a clip/track.
The use of a 2nd keyboard and Shans advice for me on Autohotkey (still thankfull) lead to an absolute massive workflow boost.
There are not much shortcuts left, that are easy on the fingers and not used by PT. But with a 2nd keyboard, that does not matter, as a single button will fire the commands.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 09-26-2016, 11:58 AM
Shan's Avatar
Originally Posted by joachim View Post
You can override the PT shortcuts. But overriding single key commands like "q" will result in not being able to use the letter "q" when naming a clip/track.The use of a 2nd keyboard and Shans advice for me on Autohotkey (still
Use...
...in front of your hotkey. When the hotkey fires, its key's native function will not be blocked. You'll then be able to use single characters in text fields such as naming clips etc:
Code:
~q::
Return
There are also multiple ways to setup your custom hotkeys to toggle on/off, thus allowing quick access to the native PT shortcut commands. Hope that helps.
Shane
Old 09-26-2016, 12:33 PM
joachim's Avatar
Originally Posted by Shan View Post
...There are also multiple ways to setup your custom hotkeys to toggle on/off, thus allowing quick access to the native PT shortcut commands.
Like the following, I learned :
+Esc::
suspend
return
And that is also a single button on the extra keyboard.
Use...
Hope that helps.
A million thanks again to you, god of Autohotkey !
Old 01-28-2018, 02:33 PM
TNM TNM is offline
Hi, how would one enter a three control button (say windows/ctrl/shift) and a letter key combo?
Also, is there any version of autohotkey out there that provides a simple graphical user interface say like the way one can create custom hotkeys on mac?
Trying to learn all this on my windows 7 laptop to see if it suits, before investing in a larger win 10 system.
Cheers and thanks.
-iMac Pro 3.2ghz 8 Core, 64GB Ram, Vega 56, OS 10.14.6/Win10 Pro, TB3 Dock & 4xSSD, UA Apollo x3 + Octopre x3, Microlite x2, Midi Synths galore, PT 2019.12
-MBP 15" 2.8ghz 4 core, 16gb ram, 750M, dual boot OS 10.13.6/10.14.6, On board analog audio out, PT 2018/2019
-Whenever I launch Pro Tools, I get wet.(™)
Old 01-28-2018, 03:11 PM
Cheers and thanks.
AHK is Windows only.
Due to how Avid messes around with certain keys, shortcuts that involve the Alt and Win key within Pro Tools will not work. Fortunately, there is more ways than 1 to perform most functions.
AHK has great documentation if you want to learn how to stack modifiers.
If you want a UI in AHK, you have to build it. They are surprsingly easy to do, but that is the only option.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 3-6-18)
Intel I7 6800k
Win 10
Old 01-29-2018, 02:31 AM
TNM TNM is offline
i realise AHK is windows only, thanks.. so you are saying that i can't use ctrl/alt/cmd(or win in windows) plus spacebar to turn on scrolling, for example, like I do now in mac through my system preferences custom shortcuts?
Or do you mean single shortcuts with the alt or win key won't work, but combinations are fine?
This is really good to know up front, thanks.
Old 02-01-2018, 11:07 AM
The problem is if you try and access any "native" Pro Tools shortcut that involves alt or win, from any sort of a macro or programming standpoint. To turn off pre roll for instance is alt+k. You could not re program the shortcut from the standard alt+k to cntrl + k for instance. The alt key in the process would be ignored in the trigger. You would have to program the shortcut to toggle the shortcut via the menu in Pro Tools.
pro-tools-pc.com
Intel I7 6800k
Win 10
A-Z keyboard shortcuts for GROUA-Z keyboard shortcuts forPS in the SECONDS ID group.. jessedtf Pro Tools 10 6 10-24-2012 10:42 AM
Keyboard Shortcuts-Apple Thin Keyboard Brian in Charlotte 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-15-2008 04:17 PM
Keyboard shortcuts with foreign keyboard torsig1967 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-08-2006 06:06 AM
keyboard shortcuts without an Apple keyboard? doublestakked 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-22-2006 06:04 AM
6.7cs7/OSX10.3.7No user defined Keyboard shortcuts hanz marathon Pro Tools TDM Systems (Mac) 7 01-23-2005 03:53 AM
