Old 09-13-2013, 07:19 AM
RoxyRiot RoxyRiot is offline
Default Inserts not showing up
I have a dbx compressor and a Pod XT Pro hardwired into my MBox and for some reason, they're not showing up under Inserts. I've just put the Pod in today, but I've had the dbx as part of my rig for months and now it's just not showing up. I'm thinking back and wondering whether it disappeared when I downloaded the PT10 update.
Any idea where these could have gone? I'm sure everything is connected properly.
Thanks.
Old 09-13-2013, 07:58 AM
sunburst79 sunburst79 is offline
Default Re: Inserts not showing up
Originally Posted by RoxyRiot View Post
Thanks.
If I'm understanding correctly you would need to select the correct sends to your hardware to access it. Once you've figured that out you could rename them so they show up as POD or DBX. Running the installed may have deleted the names or paths you were using previosly
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Instruments not showing in Inserts robert1 macOS 0 02-15-2013 09:11 PM
Inserts Not Showing FL Plugin jace314 Pro Tools M-Powered (Win) 1 09-13-2010 12:08 PM
Plug-ins not showing in Inserts Revolver73 Virtual Instruments 2 10-09-2007 11:34 AM
Mbox2 Plug-ins aren't showing up in my inserts BroganSound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-25-2007 10:52 AM
Plug ins not showing up as inserts stevesound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-17-2006 08:48 AM
