Old 08-10-2013, 11:56 AM
rmandelbaum rmandelbaum is offline
Default Breaking up multiple songs in one session into multiple sessions?
My blue band played a gig last week that we recorded. My friend has a Presonus Studio Live board, he hit record for two sets. I now have those Sets imported into 2 sessions, Set 2 and Set 2.
Is there an easy way to pull out the individual songs and put them into their own sessions?
Old 08-10-2013, 11:10 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Breaking up multiple songs in one session into multiple sessions?
There are different ways you could do it. For me, I think the easiest way would be to create a template of the master session, and use the template to create blank (no audio) sessions for each song. Use the ALL group and Control+E to split the tracks into clips for each song, then select all the tracks for one song, and Export the Clips as Files into the corresponding session's Audio Files folder. Then when you open the individual song sessions, just import the audio from its Audio Files folder.
Chris
Help Us Help You
Chris
__________________________________________________
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Gigabyte GA-Z170-HD3P / i7 6700K 4.1 GHz / 32GB Crucial DDR4
macOS High Sierra Version 10.13.6
Pro Tools HD 2019.12
Old 08-11-2013, 08:57 AM
Ben Jenssen's Avatar
What I would do:
possibly first: do a basic mix to go over the whole ting. (You would most often want the drums and bass to have the same sound on all songs if it's supposed to be like a "concert record".)
Then I'd do as many "Save as..."s as there are songs and name them, open each, select "All"-group and delete all but the song in each sessions name.
Old 08-12-2013, 08:48 AM
jeam25's Avatar
jeam25 jeam25 is offline
The way ive did ....
Save session copies ( = numbers of songs ) then rename and delete all songs but not the one you want on each session ....
- Jesus Alvarado -
Keep the volume UP !
Old 08-12-2013, 10:43 AM
guatamas guatamas is offline
Same here
Old 08-12-2013, 08:19 PM
zedhed's Avatar
zedhed zedhed is offline
In order to achieve this if I weren't using a template, I would save all settings in any of the plugins used on the first song so the integrity of all songs are kept in the context of the same 'Live' show. This way the plugins settings can be recalled (if nothing else, as a reference point) for each individual song.
Too much blood in my drugstream
Gigabyte X99 SOC Force Mobo Bios vF6d
Intel Core i7 5930k socket 2011 v3 @ 3.50GHz
32GB DDR4 Crucial RAM
System: Samsung M.2NVME SSD 960 Evo
Record: Samsung M.2NVME SSD 960 Evo
Samples: Samsung SATAlll SSD 840 Pro
Storage: 2x Samsung SATAlll SSD 840 Pro
EVGA GeForce GTX 750 Graphics
PT 11HD (v11.2.1) Omni s/pdif w Eleven Rack
HD 96I/O
Win 8.1 Pro
Old 08-12-2013, 10:23 PM
soybalm soybalm is offline
What I would do:
I like that too but save the first session as whole concert then save that as working session so you have a backup. I would just crop the songs with A+S and save the working master as whatever song. Get some sounds happening move along. As you are working on the various tunes, and evolving the mix, you may want to import the session data of the last mix into the first session mix to keep a consistency but also a well mixed set. It all depends on how good the band is dynamically and how well the levels were set. Sometimes it's so good you can set it and forget it and just do a few moves. Then just quickly move along and save as.
Dave Cournoyer-guitarist-project studio
Mac Mini late 2012, i7, Sierra
16GB PT10.3.10HD PT12.5.2
Apogee Mini-Me firewire.
Old 08-13-2013, 05:34 PM
rtman26 rtman26 is offline
I usually just split up the songs on the master session, and then delete all but one song at a time and "save as" like mentioned above. You can clean up unnecessary associated audio by removing unused clips from the region list (or whatever its called now). If you click on the downward arrow to the right of the region list and go down to "select" and then "select all unused". Then go back to that menu and down to "clear unused" and click on REMOVE (DO NOT DELETE OR YOU WILL BE MISSING AUDIO IN YOUR OTHER SESSIONS). Should clean up your region list nicely.
Old 08-13-2013, 09:24 PM
cwsand's Avatar
That's why I suggested exporting the audio files to individual sessions and keeping the master session intact - I've accidentally deleted stuff I didn't mean to while multiple sessions were sharing the same audio files. Whenever I delve into a project like this, I keep at least one copy of the master session somewhere that it won't get touched - like another drive and/or a DVD backup. It's way too easy to lose stuff in Pro Tools when copying, consolidating and deleting audio. I really wish PT wouldn't permanently delete audio - either send them to the recycle bin or have its own bin that can be emptied when you're ready for it - would have saved me SO many times!
Chris
Help Us Help You
Chris
PreSonus Digimax LT
Old 08-14-2013, 06:47 PM
I actually keep a master as well, I think we just go about it in different ways. Exporting is probably a lot less tedious.
Bit of an odd one maybe... multiple songs, one session AdamPT8 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 02-27-2010 06:41 PM
Multiple songs per session... Sascha Pendegraft Tips & Tricks 5 10-24-2007 11:00 PM
Mixing Multiple Songs In One Session Keniko 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-20-2007 05:52 PM
Multiple songs...one session.... LFarah Pro Tools M-Powered (Mac) 2 11-20-2006 10:45 AM
Multiple songs in a session or one for one? Jeff Hodges Tips & Tricks 5 02-05-2002 12:59 PM
