Old 09-11-2010, 08:00 PM
jace314 jace314 is offline
Default Inserts Not Showing FL Plugin
Hey, Im running M-Powered 8.03 Essentials on my Windows Vista PC, and My Mac. Now my MAc shows Reason as a plugin, and that works frine with rewire.
However, on my PC. I have installed 8.02, then installed the updated 8.03 and all I have under inserts when I create a new track is the PT plugin Structure.
Im out of ideas on how to get FL Studio to show up in the insert plugin?
PLease throw me some ideas...
Thanks,
Jace
Old 09-13-2010, 11:08 AM
spkguitar's Avatar
Default Re: Inserts Not Showing FL Plugin
Which version of FL Studio are you using? I would imagine it is the latest?
Also, you said Structure is the only plugin available? If so, something is definitely wrong. On the standard Pro Tools 8 installation, there should be many others available. Are you installing to the default location? Is your Windows Vista installation 32-bit or 64-bit?
Inserts not showing up RoxyRiot macOS 1 09-13-2013 06:58 AM
Instruments not showing in Inserts robert1 macOS 0 02-15-2013 08:11 PM
Plug-ins not showing in Inserts Revolver73 Virtual Instruments 2 10-09-2007 10:34 AM
Xpand not showing up in inserts list PTHolz09 Virtual Instruments 0 08-06-2007 11:58 PM
Plug ins not showing up as inserts stevesound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-17-2006 07:48 AM
