Adding Plugins to a Track Region
Hi Guys,
I've been searching on here and google for information on how to add a plugin just to one region of a track but have come up short. Has anyone ever done this before? If so, how? Thanks for the help. Matt |
Re: Adding Plugins to a Track Region
the only way to do this is to process the region using audio suite version of the plug in.
What I do is 1. instantiate the plug in on the audio track insert and set the settings how I want. 2. I save the setting and name it (click the little arrow/triangle thing by the window used for selecting settings pre sets) 3. De-activate the plug in... not remove. De-activate. hold command and control then click on the plug in instantiation on the mixer to de activate the plug in (I think thats the key command??) 4. Select the region I want to process and head to the audio suite plug in list and select the plug in I just set up. 5. Once it opens I click in the settings and presets window and choose the setting I just created. 6. Hit process and process the file. 7. There are some other setting that apply to the processing of the region, things like continuos file, timeline vs region bin for the final processed version. . etc... I suggest checking out the manual for the section on Audio suite to go over what those settings do, but mostly I use the default setting |
2 other options:
1) If you want to bring in one or more plug-ins that are not used at all on the other regions, you could automate the bypass function of the plug-in(s). 2) If you just want to change the parameters of plug-ins you are using on other regions, you could automate all parameters of the plug-in(s) (or just the one's that need to change) and make the necessary changes for the region. If you are not familiar with how to do the above mentioned things read the Automation chapter (Chapter 42 in v8) of the Pro Tools Reference Guide.
Chris Neal :: South Plains College .: Program Coordinator & Asst. Professor in Sound Technology .: [email protected] .: Pro Tools Certified Instructor .: Pro Tools Expert Certified in Music |
Not true. Three words: Plug in automation.
Pro Tools 10.3.3 | HD Native | HD I/O 8x8x8 | Mac Pro 8 Core Westmere | 24GB RAM | OSX Lion 10.7.4 | API 3124 | Chandler TG-2 | UA 4-710d | Empirical Labs Distressor EL8X | Kemper Rack | |
Learn it...live it...you will use it a lot
Answering the original question, there is no clip-based/region plugins in ProTools (this if for those who've actually used programs that have true clip-based plugins.) Bypass automation is a workaround and AudioSuite plugins are really closer to replacement (since you're rendering a file and putting it in the original files place.) If you use the AS method and are used to clip-based, then remember to duplicate the playlist before processing so you're not hunting for the originals if you need to change the plugin settings.
When I was very very new to mixing I thought if you wanted to add an effect to only one part of the vocals lets say, you would apply it to that part of the track only (which is what he is describing). I soon found out that you just create another track. And another and another. I thought most songs only had like 5 or 6 tracks, one for each instrument. Boy was I wrong.
...Unless you are talking about creating aux tracks and using automation to send parts of the vocal track to aux tracks with different time-based effects on them. That's the proper way to do it. |
I contend that it's 2 words. Let's have a multi-page debate about it.
Is state-of-the-art one word? German-American? Twelve-year-old?
Keeping region color unchanged when moving or adding a track? | mixaudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 11-10-2010 01:54 PM |
Mysterious region adding in 8.0cs1 | brassandzin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-12-2009 03:37 PM |
adding effects to a portion of the region | crownstatus | Pro Tools M-Powered (Mac) | 5 | 10-11-2008 07:19 PM |
adding versus importing into region bin | srees | Pro Tools TDM Systems (Mac) | 0 | 09-06-2007 05:42 PM |
Pro Tools Adding .A(x) extensions to region names on import | Joel Dougherty | Post - Surround - Video | 4 | 05-31-2007 10:45 PM |
