Old 06-10-2009, 01:45 PM
grateful grateful is offline
Default iMac to ext. hard drive to 003 connection. Will it work?
Hello,
I just got an iMac with 2.66GHZ and 4G Ram and want to record onto an external firewire drive. The iMac has a firewire 800 port and hubs are hard to find or don't work well. There is an unfavorable review on the Belkin 6 port firewire hub.
Is it true that I can use a firewire 800 to 400 cable out of the iMac and into the external Hard drive, then have a cable out of the external hard drive and into the 003 rack? If so, is this as good as finding a high quality hub and having them on 2 seperate inputs?
Thanks for your help,
Grateful
Old 06-10-2009, 02:25 PM
anthonylv64 anthonylv64 is offline
Default Re: iMac to ext. hard drive to 003 connection. Will it work?
You dont need a hub, just get a cable 9 to 6 pins, available at newegg.com, or best buy, or fry's, connect 003 to Imac, then from the 003 to the hard drive, then from the hard drive you can keep adding other hard drives, daisy chained. or you can go from the I mac to your hard drive and then the 003, either way will work, i do that with mbox 2 pro and Mac mini.
Old 06-10-2009, 02:27 PM
Separate inputs are still the same bus, makes no difference IMO
Old 06-10-2009, 09:46 PM
srslab srslab is offline
Yes, I go from my Macbook pro firewire 800 using the 800->800 to my Western Digital Mybook studio then 800 -> 400 to my 003r.
If I go to the 003R then hard drive I get frequent drop outs.
James Shelby
SRS Labs
Aurora, Colorado
Old 06-10-2009, 10:06 PM
I used to go to the Mbox 2 Pro first, until this morning, my hard drive would't start, I thought it was gonna die, and it's fairly new, so after the big scare, I decided to switch and got MacMini-->Hard Drive-->Mbox, and it started right away, so I guess I'll leave it like that from now on, I know I gotta get a second hard drive, and it'll be a Glyph, as soon as budget allows.
Best external hard drive connection? Naagzh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 04-03-2008 01:56 PM
external hard drive connection problem semicntrldchaos 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-26-2007 11:32 AM
FW Hard Drive connection help.... rabs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-29-2007 09:48 PM
Lacie d2 extreme Hard Drive Connection? carnology 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-28-2007 11:02 AM
External hard drive connection to iBook G4/PT MP 7 syd Pro Tools M-Powered (Mac) 3 02-25-2006 07:33 PM
