Old 03-07-2009, 04:12 AM
Jussi Jussi is offline
Default sync iMac with 003 and iMac with Mbox2?
We have two iMacs, one with 003 Factory and the other with MBox2.
We need to record ten tracks (most of them drums) at the same time.
Solution?
I guess we could just use two systems, a separate session on both, and then later on import the two extra tracks (such as toms) to the session recorded with 003. The problem is, how to start recording on both sessions at the same time exactly. Is there any way?
(We are waiting for a M-Audio 2626 pre-amp to get more tracks to the 003 system, but meanwhile...)
mp (8x2,8ghz 8gb) mbp (c2d 2,53ghz 4gb) osx10.6.3 pt8.0.3 mptk2 mbox2
www.myspace.com/pukspace
eSoundz name: jus11
Old 03-07-2009, 06:11 AM
Whiteyguitar Whiteyguitar is offline
Default Re: sync iMac with 003 and iMac with Mbox2?
The 003 you have 8 inputs plus you also have the SPDIF inputs = 10 inputs you just need a SPDIF output from another digital mixing board or if the M-box2 has SPDIF out then you might be in luck but I'm not sure of the M-Box2.
Stay true to the sound,Less is best
Old 03-07-2009, 06:09 PM
That would be great, but as Mbox2 (allthough it has the spdif output) is usb powered and 003 firewire connected, is that possible? Has anyone used 003 & Mbox2 the way Whiteyguiter proposed?
eSoundz name: jus11
Old 03-08-2009, 11:55 AM
Anyone?
eSoundz name: jus11
Old 03-09-2009, 04:24 PM
DigiTechSupt's Avatar
On the first system set it to send MTC.
On the second have it set to sync to MTC.
Connect both of them via SPDIF and have one be the master clock, the other will sync to SPDIF.
Avid Audio Tech Support
Support FAQ
Installing Mbox2 Pro on iMac fly-deluxe macOS 2 10-02-2013 12:58 PM
crackle noise that sounds like a sync issue with new MBox2 and iMac chemasol 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 04-24-2010 10:24 PM
New iMac cannot detect Mbox2 Pro n_k_rock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 11-30-2009 06:23 PM
Mbox2 Pro on iMac junter Pro Tools TDM Systems (Mac) 2 01-16-2009 10:55 AM
Trying to set up mbox2 on new intel iMac allinoneword Pro Tools TDM Systems (Mac) 1 07-16-2006 03:49 PM
