How to calculate exact size of wav file
Hello. I'v google'd around trying to find a formula for this. I finally found :
size = sample rate * number of channels * (bits per sample /8) * time in seconds. So a 44.1 hHz, stereo 16 bit wav file lasting 60 seconds should be : Size = (44.1 * 2 * (16/8) * 60) / 1024 Size = 10,3359 MB I tried recording in protools at 60 bpm for one minute in stereo. Looking in the Project window in ProTools it says each channel is 5.07 MB, wich is 10,14 MB in stereo. In addition I looked at it in OSX Finder, and it says one channel is 5.1 MB, wich is 10.2 in stereo. All this different results makes me a bit confused. Am I using the wrong formula or does both ProTools and Finder calculate things differently ? I would apreciate someone with insight clearing this up for me:) |
Re: How to calculate exact size of wav file
Just looks like a little rounding is going on. I would forget about the formula take the number that you got when you recorded for 1 minute (I don't think the bpm matters at all).
I recently checked this out for a live recording I was about to do. I wanted to know if I could burn the session to 1 DVD and send it home with my friend who has a pro tools rig and would be doing the mixing. I figured out ahead of time that each minute of recording (@ 24 bit 48KHz) took ~8.7 MB. So I multiplied 8.7MB X 4 tracks X 90 minutes = 3132 MB or 3.13 GB. In the end this almost exactly what the file sizes were. J |
So the calcuation is right ?
Either way is close enough, isn't it? It is only .03MB difference per track. Though, I would think that the Pro Tools Project Window is more accurate since it goes out one more decimal place.
J |
You're just calculating the data - there's also the header info, BWF chunk, overview, region data chunk, etc....
I see. Well, thank you for all the answers. I guess the formula is correct when calculating only the raw data.
It's about 10 meg a min for full stereo (44.1 16BIT)
Approx (with no maths) A:)
I Love Audio!!! |
Back in the days of OS9 before we had OSX and greater disk capabilities Digi made the numbers available.
16/44 1trk 1 min=5mb 2trk 5 min=50mb 2trk 60 min=600mb 24trk 1 min=120mb 24trk 5 min=600mb 24trk 60 min=7gb 16/48 1trk 1 min=5.5mb 2trk 5 min=55mb 2trk 60 min=662mb 24trk 1 min=132mb 24trk 5 min=662mb 24trk 60 min=7.8gb 24/44 1trk 1 min=7.5mb 2trk 5 min=75mb 2trk 60 min=900mb 24trk 1 min=180mb 24trk 5 min=900mb 24trk 60 min=10.5gb 24/48 1trk 1 min=8.2mb 2trk 5 min=83mb 2trk 60 min=991mb 24trk 1 min=198mb 24trk 5 min=991mb 24trk 60 min=11.6gb
URBAN MUSIC- (Hip Hop and R&B) |
Hi there chrisdee, thank you for your formula - It's helping me a lot - I was going around the bend trying to figure out how to do this and the web is just so confusing with so many different ideas and "delicate" egos and extremely strong opinions. Some of us just want simple answers that are at least in the ball park and don't require much higher education to understand.
file size | ccuwan | Pro Tools M-Powered (Win) | 3 | 06-29-2010 08:29 AM |
File size too big | jordan_ellipsis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 08-31-2006 09:28 AM |
Max file size? | audioboffin | Post - Surround - Video | 10 | 09-18-2005 08:31 AM |
odd file size | duanebonney | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 08-12-2002 01:05 AM |
odd file size | duanebonney | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-18-2002 07:33 AM |
