How to Join & Post  ē  Community Terms of Use  ē  Help Us Help You
Knowledge Base Search  ē  Community Search  ē  Learn & Support
Old 04-16-2007, 11:03 PM
MixerGuy MixerGuy is offline
Default C-8 problems - touching fader 1 writes fader 2, etc
Hello all
So from day 1 of owning my Command 8, Iíve had a pesky intermittent problem with it.
Frequently (but not always) if i have faders 1 and 2 in touch, if Iím writing on fader 1 (and not touching fader 2, and yes my hand is firmly touching the metal on the body of the unit, so it should see my finger capacitance) the Command 8 intermittently, randomly, in a stuttering sort of way..... thinks I am touching fader 2, so it completely screws up the existing automation on fader 2.
Similarly, if faders 1+ 2 are grouped, and Iím writing the group by touching only fader 1, itíll mess up the automation on fader 2 (as if Iím randomly touching fader 2, when i am not)
Firstly I updated the firmware with Digiís help, and that did not fix the problem.
Then right before the warranty expired, I got an RMA and took the unit in for service at the nearest LA repair shop, and they said that it was a grounding problem at my studio, and they could not duplicate the problem. :-(
Well, that is a bogus answer, as the power supply is TWO PRONG so it literally can not be a grounding problem. (as their ainít a ground path!)
Iíve tried different USB cables, and no, Iím not going thru a USB hub - Iím going right into a port on my G5 (or Mac Pro) so I know it is not a computer problem.
It has happened in both PT 6 and 7.
Is anyone else having this problem?
and - Digi - how can I please get this resolved? Iím a professional music mixer, and Iím about to throw it out the window.
Many thanks
Old 04-17-2007, 08:51 AM
PyramidReg PyramidReg is offline
Default Re: C-8 problems - touching fader 1 writes fader 2, etc
Hey, I have the same problem, and it seems to only happen with fader 1 + 2. I also have an intermittent "dead" fader (#7), on occassion it works fine, otherwise it never moves, and touch sensitive it is not. Any ideas from anyone would be great!
Old 04-17-2007, 12:59 PM
arvid.lind arvid.lind is offline
Same problem here!
Has this issue been covered oon the duc before? I didnīt find anything when I did a quick search in this subforum.
Arvid
Studio:
PT HD 2018.1 | HDX1 with Omni in Sonnet chassi | MacPro 2013 6-core 24 GB ram | OSX 10.12.6 | 2 x Avid Artist Mix
Old 04-17-2007, 01:08 PM
DigiTechSupt's Avatar
Are you on the latest firmware version? It should be v02.01.02.
Here's a link to the download:
http://www.digidesign.com/index.cfm?...&categoryid=36
Avid Audio Tech Support
Support FAQ
Old 04-17-2007, 02:04 PM
Thanks for your quick response!
iīll check tomorrow, itīs late evening here in europe but i do think so because I did download a firmware updater a couple of months ago, and the latest firmware is from 2003, right?
After a more thoroughly search on the duc there seems to be a grounding problem?
http://duc.digidesign.com/showflat.p...fpart=1#847100
Arvid
Studio:
Old 04-17-2007, 03:10 PM
Yes, I believe I am.
How do I confirm this?
and - i'm glad I piped up - as I am not alone!
many thanks
Old 04-18-2007, 10:49 AM
many thanks
bump
Old 04-18-2007, 10:52 AM
to confirm your firmware version, press the Utility button and then press the Select button on ch.1
if the firmware update does not resolve the issue, please go ahead and post the serial number of your Command|8.
regards,
Support FAQ
Old 04-18-2007, 02:12 PM
regards,
Thanks - yes indeed - I do have the latest firmware... and it was this way before it went in for service under an RMA - maybe they didn't know about "Rev G"
anyway - the serial # of my Command 8 is UK0018900C
I am guessing I am not "rev G"?
How would I get this? Could I get an RMA # asap to then take it in for a Rev G mod?
MANY THANKS
Old 04-19-2007, 10:14 AM
yes, please give us a call to arrange the RA.
regards,
Support FAQ
D-Command ES + Fader Madule Fader Problems FedericoF ICON & C|24 11 05-24-2013 05:27 PM
C24 select track when touching fader Jipi-sensei ICON & C|24 0 05-02-2013 03:46 AM
Basic Gain Structure Fader/Master Fader Question acmost Pro Tools TDM Systems (Mac) 1 05-16-2011 06:36 AM
Touching the fader and NOT seeing a dB level????? Chris Doremus ICON & C|24 18 09-06-2008 08:17 AM
FADER MUD - IMPOSSIBLE TO MAKE FADER WRITES IN REAL TIME Jim Casey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-22-2007 11:34 AM
