Go Back   Avid Pro Audio Community > Announcements > General Announcements
Old 03-30-2006, 04:19 PM
Avid's Avatar
Avid Avid is offline
Administrator
Default Pro Tools HD 7.1cs6 Updates
Pro Tools HD 7.1cs6 Updates for Mac OS X and Windows XP
For systems with Pro Tools HD 7.0 or 7.1
Available for download from the Pro Tools CS Updates page:
www.digidesign.com/download/cs/
What's Fixed in Pro Tools HD 7.1cs6?
In addition to all previous fixes, Pro Tools HD 7.1cs6 for Mac OS X & Windows XP contain the following:
Fixed: Under Certain Conditions, Recorded Files Could End Up Earlier on the Timeline than Where They Were Recorded (Item #74487)
  • When recording multiple tracks, files could be recorded out of sync with each other unless the Delay Compensation state had first been toggled on/off, or off/on.
Fixed: Renaming a Surround File Results in File Channel Suffixes Being Ordered Incorrectly (Item #72531)
  • When a file was renamed from the region list (using the menu command or double-clicking), *the file suffixes would incorrectly change in both the timeline and the region list, but the file order would remain correct.* Instead of renaming the audio files in the standard film format (L, C, R, Ls, Rs, LFE) the files were renamed as C, L, Rs, Ls, LFE, R.
  • If you then dragged a renamed file to the timeline, the suffixes would appear to be in order, but the files would be in the incorrect order.
  • This did not occur when renaming regions from the Timeline (or Playlist) by double-clicking with the grabber tool.
Fixed: Could Not Always Copy Time Code Values from Region Start/End/Length Fields (Item #72677)
  • Copying from these fields was not possible if there was a time selection on a playlist or the timeline. This could also potentially affect some third party post applications that required the use of these fields.
Fixed: When using Expansion|HD, Instantiating a Plug-In During Playback Could Result in an DAE -6031 Error (Item #74761)
Pro Tools HD 7.1cs6 for Windows XP also contains the following:
Fixed: Unable to Spot Audio into Pro Tools from some Third Party Applications (Item #71235)
  • This bug affected some third-party applications that are used with Pro Tools.
Administrator
HTML code is On
Pro Tools HD 7.3.1cs6 Updates Avid ICON & C|24 0 01-29-2008 01:13 AM
Pro Tools 7.3.1cs6 Updates for HD, LE, M-Powered Systems Avid Technical Alerts 0 01-29-2008 12:52 AM
Pro Tools LE 7.1cs6 Updates Avid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-31-2006 05:35 PM
Pro Tools LE 7.1cs6 Updates Avid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-31-2006 05:34 PM
Pro Tools LE 7.1cs6 Updates Avid General Announcements 0 03-31-2006 05:32 PM
