How to Join & Post  ē  Community Terms of Use  ē  Help Us Help You
Knowledge Base Search  ē  Community Search  ē  Learn & Support
Old 09-30-2019, 09:31 AM
Neale Neale is offline
Default Plugins not scanning nicely
Had to wipe system drive and reinstall. Boo. But at least itís a clean system now. OS 10.12.6 on a Mac Pro 5,1.
Firstly, izozone8aaxhook freezes my scan. Didnít before. Installed via the iZotope installer. On a fresh plugin scans (after deleting databases), scan will freeze at that plugin. After having successfully scanned all plugins, putting that one it, the scan will randomly freeze at other plugins.
Secondly, Iím getting ďthese are not 64-bit pluginsĒ alerts on plugins I have used for a while. Exponential Audio reverbs, Kush Audio plugins, and only some (Lindell Audio) Plugin Alliance plugins. Latest version all, and again, a fresh installation.
Thoughts?
Old 09-30-2019, 09:44 AM
jeam25's Avatar
jeam25 jeam25 is offline
Default Re: Plugins not scanning nicely
Hi did you try trashing PT preferences ?
- Jesus Alvarado -
Keep the volume UP !
Old 09-30-2019, 09:56 AM
Haven't many people been reporting strange problems regarding izo8 lately? I'd first remove that from plugins folder and see if PT scans nicely without, then add it back and if there is a problem then contact vendor not Avid.
Old 09-30-2019, 10:02 AM
jeam25's Avatar
Yes it is. Im following this topic very closely and found that a lot of companies are aware of it. What i found common reading a few of them is that the error is an authorization issue due to a corrupted file. There are another things but this is the common between them. All they suggest trashing pref as first step. I would thing it is releated to some OS update who knows.
- Jesus Alvarado -
Old 09-30-2019, 10:04 AM
Well...
1) been using PT since 2004. Not calling myself a master of anything, but Iím used to its peculiarities, including trashing prefs (see my OP... I use Mr. Gatesí incredibly handy utility), plus Iím annoyed in thinking that they still havenít fixed the ďfreezes on scanning more than 100 pluginsĒ thing so Iím still in the habit of scanning in batches of 100 if I ever trash them dbases and prefs.
2) been using these plugins for ages. No issues until I needed to reinstall over the weekend. As such, I would have to imagine itís a PT thing rather than a plugin thing, hence me trying to find an answer on the forum before I submit an Avid ticket. Of course I will contact the plugin vendors if Avid has no suggestions, but considering (for example) the Kush plugins havenít been updated in a while and they were still working for me, I have to wonder why it would be the plugins.
Old 09-30-2019, 10:08 AM
jeam25's Avatar
Originally Posted by Neale View Post
Well...
Hi and sorry read to fast didn't saw that you trashed prefs. But would be nice openning a ticket with vendors and if possible let us know the outcome. By now you can search as me and you can find a few vendors aware and their steps trying to resolve this.
- Jesus Alvarado -
Old 09-30-2019, 10:12 AM
Also many have reported strange issues with latest Sierra updates, so simply upgrading to High Sierra usually resolves the problems.
Old 09-30-2019, 10:18 AM
Only thing that has changed has been my wiped system drive. Plugins have been used successfully since their latest versions, passing the PT scan and being used in sessions. The same versions of my OS, plugins, and PT worked before this weekend.
So before I go to the plugin vendors to see if thereís something they can do with their plugins that were working fine before, I want to see if thereís a workaround in PT because there are workarounds. Like deleting those FB plugins to allow Komplete Kontrol to work properly, or scanning <100 plugins at a time after deleting the database or PT wonít like it.
I mean, remember having to delete that database folder from EVERY HARD DRIVE that was attached to the computer you ran PT on? Iíve done some stuff. Iím thinking this is a PT thing.
Old 09-30-2019, 10:23 AM
I'm thinking this is Apple thing as people have started reporting this kind of problems after latest Sierra security updates, iOS13 updates or whatever Apple related
jeam25's Avatar
Well as janne suggested you may want to remove those or all 3rd party plugins and start adding by group isolating the ones giving error. Also checking for the lastest installers is really important.
- Jesus Alvarado -
scanning plugins bongo_x Pro Tools 10 1 03-29-2016 08:50 PM
ProTools scanning plugins on every launch? TimNielsen Pro Tools 12 2 02-20-2016 08:50 AM
First does quit on launch when plugins scanning clausiii Pro Tools | First Discussion 9 09-19-2015 02:48 AM
10.3.10 ran out of memory scanning plugins crizdee Pro Tools 10 29 02-08-2015 12:24 PM
Live Lite 7 for Digi not re-scanning plugins Gothboy Virtual Instruments 0 09-21-2009 10:10 AM
