Old 01-31-2019, 02:38 PM
Default Re: ProTools not optimized for your Mac warning
Originally Posted by skippy View Post
Hi, just getting back into audio & video. My 2008 MacPro died recently and decided to get the i7 Mac Mini, running OSX 10.14.2, did a PT9 to PT 2018.12 upgrade, all fired up and working well.
And this has what to do with this thread?
Old 01-31-2019, 03:24 PM
Oliver M Oliver M is online now
Originally Posted by musicman691 View Post
And you know that how?
I could tell you but would have to kill you. 😉
PT2018 is 64 bit and doesn't have 32 bit code.
If I would be in your shoes I would refrain from posting about things you obviously have no clue about.
BScout gave you a very nice hint, use it.
This is my last comment on this subject.
Old 01-31-2019, 10:32 PM
Sardi Sardi is offline
From memory it’s a PT QuickTime process. Been a while since I checked, but pretty sure that’s what it is.
Old 05-09-2019, 09:51 PM
nedorama nedorama is offline
Pro Tools QuickTime Server is still 32 Bit, which is what is triggering the warning since it launches when you launch Pro Tools.
Regards,
Ned
Monkey Boy Studios
2019 16" MBP, 32GB, 1TB SSD; OSX 10.15.7; 4TB USB-C G-Tech External
Summit Audio 2BA-221, TLA-50 -->Focusrite 18i20 3rd Gen, Eleven Rack, Pro Tools 2021.3
Plugins, Virtual Instruments, and real ones
Old 05-10-2019, 03:35 PM
KMcK KMcK is offline
^ This
http://www.imdb.com/name/nm2384808/
Old 06-27-2019, 02:52 AM
markanthonybr markanthonybr is offline
And you know that how? PT2018 is 64 bit and doesn't have 32 bit code.
Unfortunately you're wrong Pro Tools Quick Time server is still 32Bit and easily confirmed from the Activity monitor app on a Mac
Old 07-24-2019, 12:35 PM
sjallyn sjallyn is offline
ProTools QuickTime Server is 32 bit, that would seem to be the culprit.
Old 12-29-2019, 07:57 AM
Arno Peeters's Avatar
Arno Peeters Arno Peeters is offline
I got this warning too, since I updated to Mojave recently. I run 2019.12. It's says in the Activity Monitor it's Pro Tools QuickTime Server which indeed still is 32bit...
Code:
Analysis of sampling Pro Tools QuickTime Server (pid 459) every 1 millisecond
Process:         Pro Tools QuickTime Server [459]
Path:            /Applications/Pro Tools.app/Contents/QuickTimeServer/Pro Tools QuickTime Server.app/Contents/MacOS/Pro Tools QuickTime Server
Load Address:    0x1000
Identifier:      com.avid.ProToolsQuickTimeServer
Version:         1.0 (1)
Code Type:       X86
Parent Process:  Pro Tools [321]
Date/Time:       2019-12-29 16:55:43.186 +0100
Launch Time:     2019-12-29 16:49:20.534 +0100
OS Version:      Mac OS X 10.14.6 (18G2022)
Report Version:  7
Analysis Tool:   /usr/bin/sample
?? How could that be?
Arno Peeters
Tape TV Productions
Old 12-29-2019, 09:20 AM
Code:
Version:         1.0 (1)
Code Type:       X86
Report Version:  7
If you looked at the announcement Avid put out about 2019.12 they said it was limited support for Catalina because of certain video codecs. It would stand to reason this also carries over to Mojave. Avid still hasn't totally solved that part of the equation yet.
Old 12-29-2019, 09:24 AM
Thanks: I knew about codecs, but wasn't sure it that would mean the actual engine runs in 32bit.
Arno Peeters
Tape TV Productions
Warning Message From ProTools M-Powered Essential 8 Aditya86 Pro Tools SE and Essential (Win) 2 05-13-2011 05:10 PM
Protools 7.2 warning ! Stjernholm Pro Tools TDM Systems (Mac) 3 08-14-2006 01:15 PM
Protools quits with no warning Gio Mix Pro Tools TDM Systems (Mac) 4 12-18-2003 09:16 AM
is Protools LE 5.0.1 optimized for the g4? The General Lee 001 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-14-2000 09:47 AM
16-bit v 24-bit Optimized Mixer David Wright Tips & Tricks 1 08-16-2000 11:09 AM
