Old 07-21-2013, 07:36 AM
juh juh is offline
Default Problem with cmd+d function
Hello
I noticed a very strange phenomena with the 'cmd + d' function (Protools 10.3.6 on Macpro Lion).
Let's say I have a bass drum clip on one audio track.
I want to duplicate it every bar, so I select the sample on one bar length and use the 'cmd +d' function several times until the end of the song (I'm in absolute grid mode).
But when I zoom in one duplicated clip start, it doesn't start right on the bar line, but few samples before, and it's worse when I zoom in the 50th duplicated clip !!
So I have to move again every clip to get them start right on the bar, which is very long and laborious ...
Any help ??
Thank you !
Juh
Old 07-21-2013, 08:19 AM
KMcK KMcK is offline
Default Re: Problem with cmd+d function
That is why you should use the loop region function and not the duplicate function. Duplicate (cmd+d) has always had that issue, it's due to sample rounding or something like that. If you use the loop region function instead it will stay on the grid.
http://www.imdb.com/name/nm2384808/
Old 07-22-2013, 04:40 PM
juh juh is offline
Thank you KMcK.
The problem is that I've the same problem with the Loop region function !
I consolidated my sample on one bar then extended it with F6 tool, but when I zoom in one reproduced clip it's out of the grid.
The only solution I found is to quantize clips ...
Can't believe all those gifted engineers working on new PT versions couldn't yet solve the problem.
Old 07-22-2013, 06:04 PM
Stig Eliassen's Avatar
The phenomenon is called sample-rounding, and can happen when you use Bars|Beats as the main time scale. I use Bars|Beats almost exclusively, and I use the selector tool (Grid mode) to select clips for duplication, type in the start/end values or Option-drag (Relative grid mode) the clips to copy them to a new location. Page 767 and 770 in the Reference guide explains this.
That being said, I may have experienced sample-rounding many times without knowing it. If I can't hear anything wrong...
Old 07-23-2013, 03:40 AM
tj_davies tj_davies is offline
Is there a way to stop a looped region from looping?
For example I have an 8bar-loop.
To begin with I want to loop the first two bars 4times. I do that with the loop trim tool.
Then after the 4 loops I want to extend the loop to a 4 bar loop.
Is this possible without having to look in the region bin to find the non-looped clip and pull it out of the region bin?
Thanks for any help,
Timothy
G5 10.8.5
PT 10.3.9 HD2
www.pearls-music.com
Old 07-23-2013, 01:33 PM
Timothy
Yes, you can right-click a looped clip > select Unloop... > trim it to desired length > switch back to the loop trimmer.
Old 07-23-2013, 01:58 PM
juh juh is offline
Thank you PT Lover.
I agree, there are not big differences, except when you duplicate dozen times several clips containing bass drums playing together, phasing problems can happen ...
Old 07-23-2013, 02:07 PM
Originally Posted by juh View Post
Thank you PT Lover.
Sure, that is true.
Have you tried any of the methods I described to get around sample-rounding errors?
Old 07-24-2013, 02:22 AM
Thanks,
Timothy
G5 10.8.5
PT 10.3.9 HD2
Old 07-24-2013, 05:03 AM
juh juh is offline
Yes, I tried the Repeat function is the edit menu, I tried to alt-grabb the clips and tried F6 loop mode but all of it doesn't solve the problem...
New to Pro Tools - problem with volume function PXC Pro Tools TDM Systems (Mac) 3 12-29-2008 10:24 AM
Problem with bottom scroll function ducada 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-14-2008 01:21 PM
Problem with DIM-function talkback GVDB ProControl, Control|24, Command|8 20 03-11-2003 10:09 AM
Problem with Dizzy's soft clip function jackruston Pro Tools TDM Systems (Mac) 35 04-29-2002 07:36 AM
Grid function problem pepperman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-08-2000 10:59 AM
