Old 07-19-2013, 02:36 AM
lukeyy lukeyy is offline
Default Importing an audiofile into PT10
I´m importing audiofiles into my mixed session and whenever I replace a file with another one at the same place it "destroys" all my automation data I´ve got on the track - how can I fix that? I want to keep automation (everything also bus and stuff..) and JUST replace the audiofile..
thx
Old 07-19-2013, 04:52 AM
joachim's Avatar
joachim joachim is offline
Default Re: Importing an audiofile into PT10
did you actually use the "Replace Clip" function within the Clip List Menu
or
were you manually dragging the new audio to the position of the old one ?
Some info on the version of your OS and PT might be helpfull.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 07-19-2013, 04:59 AM
tj_davies tj_davies is offline
thx
Turn Automation follows Edit off.
Hope it helps,
Timothy
G5 10.8.5
PT 10.3.9 HD2
www.pearls-music.com
Old 07-19-2013, 05:22 AM
joachim's Avatar
Or use "Replace Clip" command in the clip list menu : leaves the automation untouched.
(And no danger to forget turning "automation follows edit" back on )
Old 07-20-2013, 04:09 PM
thx guys!
Issue importing PT10 bounced stereo file into FCP Joshua Lopatin Pro Tools 10 6 07-10-2012 12:15 PM
Issue importing PT10 bounced stereo file into FCP Joshua Lopatin Post - Surround - Video 0 07-09-2012 10:16 AM
Importing Logic into PT10? GORILLA macOS 3 02-06-2012 10:22 AM
Can't sync audiofile with Melodyne DavidHeylen Virtual Instruments 1 04-08-2009 12:21 PM
AMS Audiofile SC to Protools. rhumphries Post - Surround - Video 5 03-18-2004 12:55 PM
