mbox2 mini buffer sizes missing
So, my mbox2 mini buffer sizes have all disappeared but 512 samples. I've installed the new drivers multiple times. They seem to sometimes solve the issue, but then I have to reinstall them over and over again as the settings keep disappearing. Even then that doesn't always work and is a lengthy workaround anyway. I'm trying to clean up a mix that is having some playback issues and really need the 1024 samples setting back.
I'm running W7 64-bit. |
Re: mbox2 mini buffer sizes missing
I would try disconnecting the Mbox and going to Control Panel>Uninstall a Program, and removing any Mbox drivers(and any other Avid hardware drivers if you see any). Then reboot and install the Mbox driver and cross your fingers.
Seems to have worked for now. Thanks.
update: They disappeared again after only an hour or two, and playback is affected. |
Did you go into Control Panel>System>Device manager and turn OFF power management on all USB ports?
Do you have ASIO4ALL installed? I've had similar issues with it installed.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Power management appears to be off by default on all the usb ports. I have had asio4all installed, but uninstalled it as I had problems with it.
Mbox2 mini buffer setting C7.5 W8? | jamwerks | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-05-2014 08:31 PM |
Buffer Sizes? | Raoul23 | Pro Tools TDM Systems (Win) | 2 | 01-26-2012 03:29 PM |
New H/W Buffer Sizes | DrSync | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-23-2008 12:56 PM |
7.4 and buffer sizes | JrummerJ | Pro Tools M-Powered (Mac) | 14 | 01-13-2008 05:37 AM |
constant buffer errors with mbox2 mini - a clue anyone? | zornizer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-04-2007 12:15 PM |
