Old 08-24-1999, 07:42 PM
spandol spandol is offline
Default Buffer Underrun Errors
I have been getting this error alot lately. It has never happened so much before. This time I got 2 successful burns out of 10 CD's. Is this something that will be fixed in the upcomming version (a system 8.6 problem)? Or is there something I can do to stop it? I tried using an image file but it didnt help. I also booted up from an 8.5.1 system and this had better luck but I still lost alot of CD's
I am using:
Powermac 9500/200
MLCD 2.1
System 8.6
Philips CDD 2600 CD-R
Thanks,
Steve
Old 08-25-1999, 03:44 PM
Digi Engineering Digi Engineering is offline
Default Re: Buffer Underrun Errors
Steve,
Might have been your recent upgrade to OS 8.6. In that case, the upcoming version of MLCD (2.2) might help.
Since upgrading my beige G3 to OS 8.6, I get less underruns with MLCD 2.2.
Do you have Toast? Do you get buffer underruns with it?
-- Marc
Old 08-25-1999, 07:13 PM
Hi again Marc.
No, the only software I have ever used is MLCD. But I never had any problems until 8.6.
If you remember, I had recently sent in my burner for repair/recalibration, so I thought maybe the buffer underruns were somehow related.
It is very frustrating thought, losing so many CD's. I got 2 successful burns out of 10. Kinda expensive. Do you get the same results?
In my mind, I shouldn't have any underruns. do you get one every so often? Say 1 in 25?
Can you give me any idea when MLCD 2.2 will be out?
Would it help to raise the value in the HD buffer size in the setup menu? I think it's default is 8. Should I raise it to, say, 25?
Thanks for the help,
Steve
Old 08-30-1999, 05:19 PM
Did I lose you Marc?
Steve
Old 08-30-1999, 07:17 PM
Hi Steve,
No, I'm still here, but thanks for your concern Things have been pretty busy in Digi-land as you can tell by looking at our ProTools 5.0 page.
Buffer underruns should be a pretty rare occurrence when everything is functioning optimally. I did see a lot of buffer underruns when I switced to OS 8.6 and used MLCD 2.1.1. Things worked much better on my development version of MLCD 2.2.
You can certainly try raising your HD buffer size. It may or may not help -- hard to say since we haven't figured out for sure exactly what your problem is.
I think your best bet is trying 2.2 when it comes out which is very soon. I hesitate to give an exact date, because I don't know and I don't want to give any misinformation.
-- Marc
Old 08-30-1999, 09:19 PM
Thanks Marc.
I look forward to MLCD 2.2 as well as Pro Tools 5.0. In the meantime I'll try raising the HD buffer size. I'm trying to not burn any CD's until 2.2 because I've lost so many to buffer underruns. Hope that will work. Have any other suggestions/work arounds?
Steve
Old 09-01-1999, 10:53 AM
Hi Steve,
When you call customer support (650-842-6699), there's a lot of standard advice we give for avoiding buffer underruns. I don't know if you talked to them already (might want to if you haven't), but some of the common stuff is:
* Disable Toast CD Reader extension and/or FWB CD-ROM Toolkit drivers
* Shut off AppleTalk
* Check for SCSI ID conflicts, proper (preferably active) termination. Cabling sometimes makes a difference too. Shorter cable lengths and better cable quality help keep the signal lines clean.
* Hook drives up to the Mac SCSI bus or approved SCSI accelerator rather than a Digidesign Disk I/O card
However, if you're suddenly getting more buffer underruns after upgrading to OS 8.6, I'd tend to suspect that as a culprit. Personally, I've found MLCD 2.2 to perform better with OS 8.6 than past versions, so that might just do it for you. I'd be quite curious to know. It should be out real soon.
-- Marc
Old 09-03-1999, 04:39 PM
Hi Steve,
I'm proud to announce that the new version of MLCD, 2.2, is available for download.
Go to the "Support" section of our web site and click on "MasterList CD updates" -- or try this link: http://www.digidesign.com/serv/ftpmaps/mlcd.html
Let me know how it compares with the old version on your system. I hope that it reduces your instances of buffer underruns.
Enjoy,
-- Marc
Old 09-03-1999, 06:45 PM
Thanks for the info Marc.
I will let you know when I get it up and running. I won't be able to post for awhile because I am going out of town but as soon as I get back I'll let you know how it's running.
Thanks again,
Steve
Old 09-16-1999, 10:48 AM
Steve,
Have you had a chance to try 2.2 yet? I was wondering if it helped.
-- Marc
HTML code is On
Mbox pro 3 is a piece of garbage (buffer underrun errors) Cryos Pro Tools 10 11 02-15-2013 04:49 AM
Buffer Underrun Errors 9129 and 9092 Zuberecords 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-23-2010 01:28 AM
Keep getting a HW Buffer Underrun themadarchitect 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 19 01-08-2010 10:21 AM
buffer underrun...buffer overrun... omg save me! driveway 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 05-21-2007 05:41 AM
hardware buffer underrun meeses Digidesign Hardware & Software 2 04-29-2002 01:22 AM
