Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 12-22-2019, 01:27 PM
Undead Goat Undead Goat is offline
Default Used S1 / S3 / dock / artist
sup squad fam
im considering a hardware eucon mixer for Pro Tools. But I like to buy used whenever it makes sense.
Knowing avid, they probably have some hidden drivers that they only give you if you buy directly from them, or some other such nonsense.
that's why im asking you, just to be on the safe side, if i want to go ahead and plan it smart. because the last thing i want is to get a good deal for a used mixer only for it to not work properly because avid likes to make things as difficult as possible for some reason.
did any of you get any of these used? are there hidden restrictions for getting it used vs new? or is it pretty safe to get them used?
Old 12-22-2019, 01:36 PM
its2loud its2loud is offline
Default Re: Used S1 / S3 / dock / artist
Bought used Artist Mixes years ago. Transfer went fine. No issues downloading Eucon. Just need to coordinate between you and the seller to contact Avid for support release. Good luck finding used S1’s. They’re barely new at this point.
Old 12-22-2019, 02:06 PM
this seems to be what i want to know more about. what is eucon support release? should i be worried or is it just warranty stuff?
does the s3 have other requirements than the artist mix or is the drivers relatively the same
Old 12-22-2019, 02:13 PM
Southsidemusic's Avatar
They are all eucon devices and have no clue what you are worried about. Own a Eucon device and you will have access to the eucon software.
Use google to read up on the eucon software and drivers. Nothing hidden here.
Dunno what a ”support release” is as we bought and sold Artist series and S3’s and own a used Dock so you dont have to contact Avid about anything since hardware is not registered in your Avid account anymore like the old TDM stuff was 10-15 years ago. Just buy what you need and download the correct eucon for that device and your OS.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 12-22-2019, 02:14 PM
BScout BScout is offline
You don't need to do transfers anymore (only in the early days did you need to in order to get access to Eucontrol.)
Eucon/Eucontrol is freely downloadable. You can get it now if you want.
Warranties have very, very limited periods for Avid so by the time you buy a used Avid Eucon controller, it'll have expired.
No point transferring ownership through Avid. (there are no iLok assets, etc, connected)
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3
Old 12-22-2019, 04:23 PM
Thank you much for the clarification. Just wanted to make sure there were no hidden fees or gotchas like there used to be
i attempted to upgrade to a used pthd rig and that came with my fair share of hoops to jump through to get everything under control so figured it was worth asking this time around
Old 12-23-2019, 12:29 AM
globaleric globaleric is offline
I bought my MC Transport used, so I can also confirm that there are no gotchas.
Just check your Avid account - under your products and subscriptions you should already find a "Avid Control and EuControl" section with a Download link. In case there's no such section (I'm just not sure anymore whether mine was "always there" or something triggered it to appear) then simply download the free Avid Control app on a tablet or smartphone, and register it from within the app when launching it for the 1st time. That would definitely do the trick, and you might find the app useful, even as standalone.
Finally, after getting the used hardware and connecting it for the first time, make sure to check by selecting it from the Surfaces tab of EuControl whether it's requiring a firmware update and download/install it from there if necessary.
Mac mini 2018, i7 3.2 GHz, 32G RAM, 1TB SSD
Mojave 10.14.6, PT 2020.5 Vanilla, several Waves V13 and some Massey plugins
PreSonus Quantum, Avid S1 & Control, MC Transport, Tascam HS-P82 Field Recorder
Dock and Artist Transport LukeHoward Avid S1, S3, Dock and Control App 3 02-02-2018 07:46 PM
Dock with Artist Control Sugarfree Avid S1, S3, Dock and Control App 2 09-21-2017 05:31 AM
Dock with Artist Mix Jazzbass56 Avid S1, S3, Dock and Control App 10 09-07-2017 11:02 AM
Dock and Artist Mix next to each other picture mrtomcat Avid S1, S3, Dock and Control App 5 04-22-2017 10:30 AM
The Dock plus Artist Mix KeyplayerG Avid S1, S3, Dock and Control App 17 03-05-2016 08:28 PM
