Old 04-27-2013, 04:21 PM
thruhiker thruhiker is offline
Default Please HELP!! Save error messages
I am getting various different save errors including Can't save while translating tracks or can't locate a certain path, etc.. you name the error and I have likely had it. It happens after I have been working with the session for an extended period of time. I thought the sessions became corrupted somehow. so, I saved a template of it and then rebuilt the session from scratch. Worked great with frequent saving by me until I finished and bounced my mix. then it would not save, or let me save a copy. then gave me a bunch of C++ run-time errors and crashed. Whether I have bounced to 2 track or not makes no difference in the frequency or time of error
This is very frustrating and I've been fighting it for a week to no avail. updated, reinstalled, etc, etc... No info that I have found seems to solve the issue. I've shut off auto save function which was also giving me errors. I found that suggested on this forum, still nothing.
Please help!!! I'm desperate.
Thanks......
Old 04-27-2013, 05:45 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Please HELP!! Save error messages
Hi, It's hard to say without more info about your system and which version of Pro Tools you're running. Have you tried a clean reinstall of Pro Tools? Have you gone through all the Optimizations for your O/S? Make sure you go through everything here:
Help us Help You - READ THIS Before Posting!
And post a SANDRA report. My first thoughts are a corrupted Pro Tools install, or something wrong in Windows, or possibly some bad RAM.
Chris
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 04-28-2013, 07:03 PM
Thanks!
I am running Pro Tools 10.3.5 on Windows 7. This is a clean install of the updated software. I have performed all of the optimizations and have ran a SANDRA report which appears below.
The first error I get is:
"cannot save "Session_name" because translating tracks
Then:
Could not save "session" because access violation occurred. unable to read location: 0x250048FE.
Then I get"
Can't save due to fatal error
Then it says I need to allocate more memory and then Pro Tools shuts down.
I"ve allocated all the memory I can but still nothing. I have also disabled auto-save function.
Please see report below...and Thanks!
SiSoftware Sandra
ID
Host Name : ProToolsPC-PC
Workgroup : WORKGROUP
Computer
Model : GigaByte
Serial Number : To be fille***********
Chassis : GigaByte Desktop
Mainboard : GigaByte X79-UD3
BIOS : AMI (OEM) F11 07/05/2012
Total Memory : 16GB DIMM DDR3
Processors
Processor : Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (4C 8T 3.7GHz, 3.7GHz IMC, 4x 256kB L2, 10MB L3)
Socket/Slot : FC LGA2011
Chipset
Memory Controller : Gigabyte Core DMI2 (Sandy Bridge-E) 100MHz
Memory Controller : Gigabyte Core (Sandy Bridge-E) Integrated Memory Controller Registers 100MHz, 4x 4GB DIMM DDR3 1.6GHz 256-bit
Memory Module(s)
Memory Module : F3-12800CL9-4 4GB DIMM DDR3 PC3-12800U DDR3-1600
Video System
Monitor/Panel : Samsung SAMSUNG
(1600x1200, 40.2")
(1600x1200, 31.5")
Video Adapter : NVIDIA GeForce GT 520 (1CU 48SP SM5.0 1.66GHz, 64kB L2, 2GB 1GHz 64-bit, PCIe 2.00 x16)
Graphics Processor
OpenCL GP Processor : NVIDIA GeForce GT 520 (48SP 1C 1.66GHz, 64kB L2, 2GB 1GHz 64-bit)
Compute Shader Processor : NVIDIA GeForce GT 520 (48SP 1C 1.66GHz, 64kB L2, 2GB 1GHz 64-bit)
CUDA GP Processor : NVIDIA GeForce GT 520 (48SP 1C 1.66GHz, 64kB L2, 2GB 1GHz 64-bit)
Storage Devices
WDC WD5003AZEX-00K1GA0 (500.1GB, SATA600, 3.5", 7200rpm) : 466GB (C:)
WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm) : 932GB (D:)
HL-DT-STDVDRAM GH24NS90 (SATA, DVD+-RW, CD-RW) : N/A (E:)
Logical Storage Devices
System Reserved : 100MB (NTFS)
Audio Drive (D:) : 932GB (NTFS) @ WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm)
System (C:) : 466GB (NTFS) @ WDC WD5003AZEX-00K1GA0 (500.1GB, SATA600, 3.5", 7200rpm)
Optical Drive (E:) : N/A @ HL-DT-STDVDRAM GH24NS90 (SATA, DVD+-RW, CD-RW)
Peripherals
LPC Hub Controller 1 : Gigabyte Patsburg LPC Controller
LPC Legacy Controller 1 : T2 87-28
Audio Device : Gigabyte Patsburg High Definition Audio Controller
Audio Device : EVGA HDMI Audio stub
Audio Codec : nVidia 001C
Audio Codec : 1 0001
Serial Port(s) : 1
Disk Controller : Gigabyte Patsburg 6 Port SATA AHCI Controller
Disk Controller : Gigabyte 91xx SATA 6G Controller
USB Controller 1 : Gigabyte Patsburg USB2 Enhanced Host Controller #2
USB Controller 2 : Gigabyte Patsburg USB2 Enhanced Host Controller #1
USB Controller 3 : Gigabyte FL1009 USB 3.0 Host Controller
USB Controller 4 : Gigabyte FL1009 USB 3.0 Host Controller
FireWire/1394 Controller 1 : 13330 XIO2213A PCI Express to 1394b OHCI with 3-Port PHY
SMBus/i2c Controller 1 : Intel ICH SMBus
SMBus/i2c Controller 2 : Intel SNB-E XMB Ch 0 SMBus
SMBus/i2c Controller 3 : Intel SNB-E XMB Ch 1 SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Network Services
Network Adapter : Intel(R) 82579V Gigabit Network Connection (Ethernet)
Wireless Adapter : Linksys WUSB600N Wireless-N USB Network Adapter with Dual-Band ver. 2 #2 (802.11g (ERP), AES-CCMP, 144Mbps)
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7600
Platform Compliance : x64
Windows Experience Index
Current System : 4.8
Old 04-28-2013, 07:48 PM
Jenk2k Jenk2k is offline
I am not trying to be snarky, but the well intended link above:
http://duc.avid.com/showthread.php?t=300050
is full of dead links.
We don't have the user centricity. Until we understand context, which is way beyond presence — presence is the most trivial notion, just am I on this device or not; it doesn't say am I meeting with something, am I focused on writing something. [LIST][*]Bill Gates .NET Briefing Day Speech (24 July 2002)
Old 04-28-2013, 08:27 PM
DHL DHL is offline
The only dead link I can see is the "Search the Knowledgebase" link, and that link is accessible from the forum header!
Daniel
Asus P6X58D-E, Intel i7 930, 12 Gb Corsair XMS3 DDR3
2 WD Black Cavier 640 Gb SATA 3Gb/s 32MB Cache
Windows 10 Pro
Old 04-29-2013, 05:46 AM
Yes no problem finding the links I needed despite the dead one.
Old 04-29-2013, 06:28 AM
dave911's Avatar
dave911 dave911 is offline
Have you installed any third party plugins?
Tried starting PT with plugins disabled?
"In theory there is no difference between theory and practice. In practice there is." - Yogi Berra
Old 04-29-2013, 06:58 AM
sunburst79 sunburst79 is offline
Might not hurt to run Memtest+ either
http://www.memtest86.com/
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 04-29-2013, 08:35 AM
I do have 3rd party plugins. Slate digital stuff. as well as P&M plugins. also amplitube 3 but not using it in the sessions I'm haveing issues with.
I'll try all these suggestions tonight. Thanks!!
(-50) ERROR on Save / Auto Save oldrake macOS 1 10-14-2013 03:30 PM
Many different error messages, Pro Tools aborting or unable to click messages off riffmachine Pro Tools M-Powered (Win) 5 10-05-2010 04:15 AM
Error Messages Guitarboy Rocks 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-12-2007 12:03 AM
Mac error messages..help please? james3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-22-2005 10:08 AM
error messages Vinnie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-09-2000 01:23 AM
