Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
Old 03-08-2012, 03:51 PM
zapple zapple is offline
Default Glyph Portagig50 Oxford 936 chip OR Seeking Superquiet Harddrive
Howdy,
My currently harddrive is a little too noisy so I'm looking at other options.
I like the Glyph Portagig50 because I do a lot of mobile recording and need to keep my gear as concise as possible.
The Glyph product manual states that this unit has an Oxford 936 chip. See if this link works:
http://www.glyphtech.com/docs/610033...Quickstart.pdf
But I am not seeing this chipset supported on the AVID site for PT9:
http://avid.custkb.com/avid/app/self...p?DocId=380567
Is anyone using a Portagig50 with PT9?
Any other super quiet firewire drives people are using and can recommend?
Gracias,
Zapple!
Old 03-22-2012, 03:11 PM
antonis's Avatar
antonis antonis is offline
Default Re: Glyph Portagig50 Oxford 936 chip OR Seeking Superquiet Harddrive
A friend is using the 4TB Lacie Quadra and I am thinking of getting one of these as well. I did some research - at the time - that was the only big drive drive without a fan. Obviously this has its drawbacks regarding drive life, so if you opt to go down this route back up to something else. But not to mobile of a drive as well. But now that I am thinking about it, I believe that most of the Lacie drives (if not all of them) have the metal casing to dissipate heat and do not use any fans.
I've got a G-Raid that is currently quite noisy and I'm thinking of replacing the fan. People reporting great results with faster and quieter fans. Perhaps a bit of DIY could be another option for you?
1. Mac Pro 5.1, 2.66GHz, Twelve Core, HDN, AVID MTRX, Sync HD, PTU 2018.10, OS X 10.12.6.
2. Mac Pro 5.1, 2.66GHz, Twelve Core, Yamaha Dante Accelerator, PTU 2018.10, OS X 10.12.6.
3. D-Command ES, 24-fader.
4. Eleven Rack.
Old 03-26-2012, 10:26 AM
Default
Thanks for your thoughts. I didn't think of that, although at 10 years old and 120 gigs I feel like it's time to upgrade. Turn this little beast into a backup drive itself.
I'll take a peek at the Lacies.
Thanks,
Z!
Glyph GTO50Q discontinued...GPT50 (Oxford 944 chip) now ? Loudyman Pro Tools 10 4 04-22-2012 12:17 AM
FW 800 Enclosure Oxford Chip Siegfried Meier Pro Tools TDM Systems (Mac) 12 03-11-2010 08:15 AM
Glyph GT 062, seeking opinions chuxdaddy Storage Subsystems 1 07-16-2009 07:16 AM
Glyph Harddrive problem Mixodigian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-19-2004 10:52 AM
Mbox--Glyph X Project/Oxford 911 Chip cradel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-11-2004 08:39 AM
