Fader, Mute an Solo issues in PTLE 6.1.1
Howdy all!
Got some issues I'm woundering if anyone has seen. I have some very strange things happening with my faders. mutes and solos! Basically, something might be muted in the mixer screen and yet you can still hear it (occasionally!). Also, I might have something solo'd and yet other tracks are still being played. I've checked groups and made sure that ONLY the thing I want solo'd is, and that the other trax aren't ALT-solo'd but still the same challenges. Also I find that occasionally volumes on tracks and also auxes do not function as intened from time to time. I have to touch the fader and then it updates. This seems to happen regardless of mode (AUTO READ, AUTO OFF). Is this just a bug? Has anyone else seen it? Work-arounds? I'd appreciate any feedback. Doogz |
Re: Fader, Mute an Solo issues in PTLE 6.1.1
There is a very intermittent bug which is somehow related to the Reason plug-in.. if the plug-in is instantiated.. it can cause the mutes not to be honored.
If you can localize the problem and have repeatability with a minimal session.. let us know. Rail
I'll check that Rail - I do use Reason a bit so that could be it. I wonder if Digi are on to this - perhaps PTLE 6.1.2 will fix this. As well as undo for the mixer page! Hmmm, and auto-organise for Markers ....
Thanks Doogz |
Doogz,
I used to get this 'bug' too. Solos, mutes, not responding, etc. Now this may be coincidence or not, but back then when I first got Reason, every time I opened Reason in a PT session, I was using the Reason Example file, which has the demo song sequenced from the getgo. Since I've started opening a New Reason file, and building it myself, this 'bug' has not returned. And I've been doing some fat Reason/PT sessions for a while. But if you're already starting with a new Reason file, then that'll shoot down this theory. As I say, could be just coincidence, but also maybe worth mentioning. -rh
rh music |
Send mute/solo follows track mute/solo pre-fader | Roger_Jam_Jet | Windows | 3 | 09-24-2017 01:59 PM |
Protools 10: mute and solo aren't working. (Solo safe is not on any of the tracks.) | charlottewrinch | macOS | 2 | 04-14-2012 05:32 PM |
8.0.4 Issues (Quick Punch & Mute/Solo issues) | pauledwards | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-06-2010 09:35 AM |
Mute / Solo - Not Working!! PTLE 6.4 | DJ FADE | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-06-2005 08:56 PM |
SOLO AND MUTE ON THE MASTER FADER. | LEVON | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 66 | 09-05-2002 05:22 PM |
