Old 02-18-2010, 07:37 PM
stainless stainless is offline
Default Help with Midi files
a friend sent me a midi file as a possible secrtion in a tune- I can play the midi file in WinAmp, Quicktime, etc.
when i import it into the session, it comes in as the 4 instruments, and the track shows the midi "notes"... i hit play and I can see the signal level happening, but no sound from those tracks
I can see the level meters move as well as the fader/automation
Input and output both give me only the Digi 002 ports with 16 possible channels... i've tried numerous combinations but although i can visually see that there's a signal happening on the fade/meter... nothing works
I read the manual pg 301- 303... but nothing described seems to be of any help... It says to "Click the midi output selector for each new track and assign a Midi instrument and channel", however, other than the selections listed above I'm at a loss as to how to get any physical sound from the imported tracks
It appears the imported track is a Type o MIDI
help!!!
Stainless - G5 2.3x2, 5 GB RAM, 1.5TB, OSX 10.5.x and 8.0 002R/D8, MC Control/MC Mix, etc, etc, etc
Old 02-18-2010, 07:59 PM
Shatzer Shatzer is offline
Default Re: Help with Midi files
do you have an instrument plug in on the track in order for the midi to play through?
Old 02-18-2010, 08:58 PM
yes I tried an instrument track and inserted several different virtual instruments (that I'd used in earlier version of PT)... but I can't seem to get the output from the Midi track to the instrument tracks input
Old 02-18-2010, 09:30 PM
TOM@METRO's Avatar
In the edit Window the left panes have an option to show/hide things like I/O, inserts, and instruments etc. Make "intruments" show and chose the VI and routing that you desire. Unless you have done this already.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 02-19-2010, 08:29 AM
Thanks Tom
I'll look for that tonight-
this will give me the option to sect an input from my port/channel options on the Midi track(s)?
Old 02-19-2010, 07:03 PM
Bingo!!! thanks much
Pro Tools thought my midi files were video files mgrimm Pro Tools TDM Systems (Mac) 1 08-25-2009 02:28 PM
Converting Vision files to ProTools or general midi files!!! Paata 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-17-2008 01:11 PM
Free MIDI files vs. Purchased MIDI files AlohaMoto MIDI 2 06-07-2007 08:53 AM
Converting midi files to audio files Ormond 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-19-2003 03:23 PM
Converting Windows Midi files to MAC Midi files rdeck 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-01-2002 09:15 PM
