Old 01-03-2020, 04:26 PM
boydwgrossii boydwgrossii is offline
Default Ran out of CPU power AAE -9173
Only other program running is Mail.
2.6 GHz i7
16 GB DDR3 RAM
Am I doing something wrong?
I'm new here.
Old 01-03-2020, 04:55 PM
john1192 john1192 is offline
Default Re: Ran out of CPU power AAE -9173
2.6 GHz i7
16 GB DDR3 RAM
I'm new here.
YEP, Mail is the Culprit ... stop using it ... UPS FED EX all of them ...
NO, you are not doing anything wrong - for what we know .. which is not too much ..
can you provide some more information please !! version of PT, what you do to make this Behavior happen ... that sort of thing
thank you
john
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 01-03-2020, 05:08 PM
thank you
john
Man...you made me chuckle.
I have Pro Tools 2019.12.
I have these tracks total.
Piano Buss
-Piano T1 - VI, Comp, EQ
-Piano T1 LH - VI, Comp, EQ
-Piano T1 RH - VI, Comp, EQ
-Piano Verb - Comp, Verb, EQ
-Piano DLA - Comp, Delay, EQ
Vox Buss
-Lead Vox - Waves Tune Live
-BG Vox - Nothing
-BG Vox - Nothing
Mix Buss
Master
When I hit space bar or play, it happens every time, even when I had one track done.
Old 01-03-2020, 05:15 PM
thank you
john
I put it in my signature now. I hope.
Pro Tools 2019.12
I have a piano buss with 5 tracks in it, a vox buss that isn't being used yet, a mix buss, and a master. Mix has some compression and eq on it.
It happened even when I had 2 tracks or on just about anything. I just hit space bar or play and it happens almost every time.
Gear I has:
MacBook Pro (15-inch, Mid 2012)
2.6 GHz Intel Core i7
16 GB 1600 MHz DDR3
Intel HD Graphics 4000 1536 MB
Pro Tools 2019.12
Scarlett 2i2
Shure SM7B
Ibanez Iron Label RG
Godin 5th Avenue
Old 01-03-2020, 05:31 PM
Pro Tools 2019.12
thank you ..
Piano Bus with 5 Tracks .. more info please ?? is this a virtual instrument or audio ??
Buffer Settings ?? 32,64,128, ?? and while recording these VI's ... right !!
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 04-01-2020, 10:08 PM
thank you ..
Not sure on those other settings. I am not sure what they should be. Would you be up for a FaceTime quick thing where I can send you a link on messenger and you can see my screen?
Gear I has:
16 GB 1600 MHz DDR3
Pro Tools 2019.12
Scarlett 2i2
Shure SM7B
Godin 5th Avenue
AAE-9173 - Ran Out Of CPU Power bagoyee Pro Tools 12 263 01-17-2019 09:31 AM
AAE 9173 Pro Tools ran out of CPU power Kinh Pro Tools 11 223 12-10-2017 09:39 AM
Pro tools running out of CPU power AAE-9173 ccapretta macOS 4 12-07-2015 07:27 AM
CPU Power issues AAE -9173 errors Cryos Pro Tools 11 3 11-01-2015 03:39 AM
Pro Tools ran out of CPU power. AAE -9173 graj Pro Tools 12 13 10-27-2015 12:34 PM
