Old 11-23-2019, 02:17 PM
greeting_card greeting_card is offline
Default Standby Mode
I'm wondering if anyone can help me with this playback problem I'm having. Everything is working fine, except I cannot play along with a recording without actively recording new material. I would call this standby mode. I can create a new audio track and arm it and when the song is not playing, I can hear my audio coming through the monitor just fine. Then when I press play to start the song, no sound comes from the new track. The track does not indicate that there is any input and none is heard. I can hear new audio when I press play AND record. However, I need to just play along with the song a few times to figure out the part before I start recording.
This is my system. I know there are bound to be some compatibility issues, but this feels like a preferences issue or just having some button pressed in the transport that I don't understand.
MacOS Mojave 10.14.1
MacBook pro 13 inch mid 2012
Avid Fast Track Solo
Protools version 12.4.1
I appreciate any help. Thank you all in advance.
Old 11-23-2019, 03:13 PM
BScout BScout is offline
Default Re: Standby Mode
There are recording modes that will do this. In your transport bar, does your Record button have any letters on it? Or does it look like the standard record button as always.
In Preferences>Operation>Record
Make sure PEC/Direct Style Input Monitoring is off (unchecked)
You should also be able to turn in "I" while also "R" is switched on the track to keep input monitoring open.
Old 11-23-2019, 03:51 PM
Thanks so much for the reply. The record button doesn't have any letters on it and it looks normal.
When I go to Preferences>Operation>Record i don't see anything about PEC/Direct Style Input Monitoring. I've attached an image of that dialogue window.
Also, I don't understand the last part of your reply. Could you expand on that?
File Type: jpg Screen Shot 2019-11-23 at 3.46.13 PM.jpg (49.1 KB, 0 views)
Old 11-23-2019, 08:07 PM
Which version of Pro Tools are you running? The newer versions have a button on each track with I in it, for INPUT mode. Click that(show it shows green) and you will hear your input signal when stopped or when playing back.
Older versions of PT had an overall option that does the same(but for all tracks that are in record-ready) and that gets toggled by Alt-K.
Another option, since there are often multiple way to do things in the digital world; just add an AUX track next to your AUDIO track and set it for the same input you plan on recording(mute the AUDIO track while you rehearse the part, then mute the AUX track when you're ready to record(or leave the AUX track on so you hear MORE of you when you record(this can be handy when people want "more me" in headphones)
Old 11-29-2021, 09:28 AM
burnoil burnoil is offline
Just wanted to say thanks for this! It works fine on PT10 too.
HUI drops after Mac standby mode j20056 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-06-2009 11:35 AM
Monitoring in 003 Standby Mode? bentropy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-12-2008 06:39 AM
Monitoring in 003 Standby Mode bentropy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 11-11-2008 06:32 AM
DIGI 002 stuck in standby mode! BillyP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-26-2006 08:11 PM
001 preventing my PC from going into standby mode. scoobydoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-02-2006 08:17 PM
