Old 05-08-2020, 02:33 PM
ViciousLullabyz ViciousLullabyz is offline
Default EuCON/Ethernet Connection Question
Quick question about how to best connect my devices (Dock, S3 and iPad) to my Computer via Ethernet in the best way.
My Computer has only one Ethernet Port that I am currently using for connection to Network/Internet. I want to connect my EuCON Devices directly via Ethernet to my PC, without (if possible) introducing additional latency. So I'm wondering which of these options would be best:
  • 1. Use a network switch, plug it into the router and then connect all the EuCON Devices and also my PC to it. Will the EuCON Signals then travel directly to my PC or will they go via router, which might introduce additional latency?
  • 2. Connect a USB to Ethernet Adapter and use the network switch there to assure that the signal is not going via router, but the USB might still introduce possible latency (or compatibility?) issues too?
Any help or pointing in the right direction is appreciated. Thank you :)
Old 05-08-2020, 02:43 PM
Top Jimmy's Avatar
Switches route according to MAC addresses. If the sending and receiving MAC addresses are on the same switch, the communication is routed directly. But the sender and receiver still need IP addresses because that is the level at which they talk to each other.
Using a USB to Ethernet adapter is no different from using the onboard Ethernet adapter. You’d still need to be to be on the same LAN with a router and access point to use the iPad.
James Cadwallader
Old 05-08-2020, 02:48 PM
EddieJones's Avatar
Default Re: EuCON/Ethernet Connection Question
Either of those options would work OK.
Sent from my HMA-L29 using Tapatalk
Old 05-08-2020, 02:52 PM
Thanks for the quick answer. The iPad will also be connected via ethernet using the Camera Adapter/Ethernet Adapter Combo. So I will the plug them all into the switch and as per the above statements that should be routed directly and not do a "trip" via router. cool, thanks :)
External SSD over Ethernet connection Emi Pro Tools 2018 5 01-21-2019 02:22 PM
C24 Ethernet connection issue gary_kesling ICON & C|24 4 04-18-2018 06:16 PM
C/24 ethernet connection jmtayloraudio ICON & C|24 3 04-23-2010 10:06 AM
No Ethernet Connection? Mark McCabe ICON & C|24 0 09-25-2003 11:44 AM
control 24 and ethernet connection ianmiller ICON & C|24 3 03-02-2002 11:24 AM
