Old 10-26-2011, 05:45 PM
benderbro benderbro is offline
Default Edit window jumping around
After a looonnng time stuck in the past with pro tools 5.3, I finally upgraded to pro tools 8. I have an HD1 system for what it's worth. Anyway, while editing a TV series that I work on, I'm noticing that the edit window frequently jumps around while I'm working. For example, I might be putting a fade on a region and the timeline will jump forward so that the section where my cursor was is now off screen. Very annoying and it is slowing me down. I've tried some various different settings in preferences but it's not helping. Anyone familiar with this and know how to stop it?
"this guitar won't play that"
Old 04-21-2020, 09:54 AM
jonburr's Avatar
jonburr jonburr is offline
Default Re: Edit window jumping around
The jumping edit window (at least in 2020.3) can be fixed in
Preferences>Mixing>Controllers/ uncheck "Edit Window Follows Bank Selection" and (possibly) "Mix Window follows Bank Selection."
Jon Burr
arrangerforhire.com
Old 06-19-2021, 11:40 AM
Defekt Defekt is offline
Thank you for answering this thread 9 years after the original posters question. May have been too late to save his sanity, but it certainly helped mine. I had been pulling my hair out trying to find the setting that was causing this ever since adding my S1's. This seems to have solved it. Thanks!
MacBook Pro 2018
Pro Tools Ultimate 2023.9
EuControl 2023.11
Avid Control App 2023.11
HD Native Thunderbolt
HD I/O + Omni
Avid S1 x 2
Old 12-27-2022, 03:25 AM
Ren_or_Stimpy Ren_or_Stimpy is offline
I just solved a similar issue on my Windows laptop: waveforms were jumping around the screen when I grabbed them to trim or move.
Right-Click on PT, under Properties\Compatibility\Change High DPI Settings, I unchecked 'Overide High DPI Scaling Behaviour' and now it behaves itself.
I had a temporary fix that involved changing the display scale to 100% under Windows display settings, but it did render everything a bit small to be practical.
Mix Window Freezes but Edit Window works fine. wwicklund 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-10-2022 10:57 AM
Vertical Jumping With Edit Selection In Playlist View soundlabyrinth macOS 11 09-24-2012 06:37 PM
Pro Tools 9 keep jumping to end of Mix/Edit screen redbull Windows 2 03-25-2012 12:04 PM
PT 8: how to edit while its playing without playback jumping to where you click? marcnyc Pro Tools M-Powered (Mac) 3 12-25-2008 11:05 AM
Cannot change EDIT MODE in edit window Xavior Pro Tools M-Powered (Mac) 2 05-24-2007 12:51 AM
