Quits Unexpectedly?
I have an mbox that I was hoping to use on a PC and on my PowerBook for live recording. It won't work on the PC, and the list of things to turn off, stop, just to TRY and see if I can get it to work makes it unusable for a machine in my office that does other tasks. Looks like it would take 10 min or so of turning off stuff EACH time I wanted to use it and then turn all that stuff back on when I'm done!!!
So I get to the PowerBook (1 GHZ PowerPC G4, OSX 10.3.4, 768 DDR SDRAM, 60 gig Toshiba drive, Mac OS Extended Journalized file system). I installed 6.1 and did the upgrade to 6.4. Repaired permissions. Trying to start gives a "The Application ProTools quit unexpectedly" (since it does it every time, it's not unexpected to me!!! The help file in this forum says to go to System Preferences/Login, but there isn't such a thing (I'm a new Mac user....). It says to make sure that no offending software is being loaded. If I knew what offending software was, I wouldn't be reading the help message in the first place. It says to make sure it's HFS+ and all I can find in Disk Utilities and Get INfo is MAC OS Extended Journalized. One overriding concern is that I bought this for live recordings. Given the difficulty of getting it to work on ANY machine, it seems too flakey to depend on for a LIVE recording. I'm looking for a bulletproof means of recording to my computer and KNOWING that there won't be a problem (I've been using minidisc for recording and NEVER had a problem (except for the time I forgot to turn the mic on....)) Any suggestions? |
Re: Quits Unexpectedly?
Start here...which should clear up your problem...
http://duc.digidesign.com/showflat.p...fpart=1#313423 Pro Tools should be stable enough for live use, with some caveats... |
I've been to that page, and that's the file I referred to in my original post. I don't have a System Preferences, Lgin ITems, I don't know what offending software is, can't tell if I have HFS+. I did do most of the other things (delete preferences, etc.) all to no avail.
Pro Tools 9 wont start! Quits unexpectedly.... Quits during startup... | dbC4G | Pro Tools 9 | 11 | 03-09-2012 07:23 AM |
PT8 LE Unexpectedly Quits | metaltx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-24-2009 03:48 PM |
PT 7.3.1 unexpectedly quits | schulze | Pro Tools TDM Systems (Mac) | 0 | 04-19-2008 12:27 PM |
PT 6.4.1.Mix unexpectedly quits | polytrash | Pro Tools TDM Systems (Mac) | 5 | 03-11-2005 08:03 AM |
6.7 unexpectedly quits | pbjnus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 03-07-2005 02:31 PM |
