Center Mouse Button.
Hey, Ijust noticed that the center mouse button in the edit mode toggles between the magnifier, trim, selection, grabber, scrubber, and pencil tool. Has that always been there?
That is SOOOOOOOOOO much more convienient. Wow, I discover somehting new everyday with ProTools.
Ill suffer winter alone; ten thousand miles from home... |
Re: Center Mouse Button.
is this an acutal center mouse button, or would a wheel do the same thing (you know how ou can push in the wheel, as a button). you can click on the bar that underlines the edit,pencil,etc. icons, and that acts as all of them. it sees where your mouse is and gives you whatever tool it thinks you're trying to use. if you are by the end of an audio section it will give you the trimmer tool, if you are on a volume,pan,mute,etc.. mode on a track, it gives you pencil...i don't know if you already knew this.. but this is a good thing to use you don't have to switch so much.
Well, the wheel will work as well. I know the bar tool does the function of all those, but i cant stand that tool, it always does something else then I want it too. Clear and plainly, it is my mistake, and not really the tool, but the center button will cycle through all of them for me.
that sounds like a deal.. i dont like using the all in one tool either. Even so, it doesnt include the zoom tool if i remember. I'll have to try the wheel method.
thats of course when i finally get home from mexico next friday.. i have so much stuff in my head to put down on some tracks. talking about the zoom tool reminds me; there are so many times when i'm zoomed in, doin some editing, and ill go and accidentally hit the 'beginning of track' button on the transport, instead of maybe play or rewind (i click stuff so fast, i only have about an 80% accuracy rate lol) obviously, once i hit this, it puts me at the beginning of the track, so i have to zoom out, find where i was, then zoom back in. is there a way to like, undo, or go back to where i was quicker, or maybe a 'previous zoom' function.. i remember the dvd talking about those markers, is that my solution?? thnx |
i love my apple iPhone! |
i do hit space for play/stop, its usually im going to hit the rewind button, and end up hitting the 'beginning of track' button instead
thats a good idea.. i have the intellimouse, so i guess i could customize my buttons, but it still seems like i will be hittting a number of clicks if i accidentally hit the beg. of track button. i think the little yellow markers are my answer, i need to read up on them. |
That's a good one. Hit the number-pad 'enter' (all the way to the right of the keyboard) and PT will drop a memory location right there at your cursor. Hit it again and you don't have to fill out any name-dialog box.
Also the keypad numbers 1 and 2 will do FF and REW for you, if you have PT in Numeric Keypad Transport Mode (Preferences> Operation). |
Mouse Button Setting won't save... | Jason Stygar | VENUE Live Sound Systems | 1 | 02-10-2010 03:32 PM |
Mouse button | Scott Fahy | VENUE Live Sound Systems | 3 | 07-15-2007 08:54 AM |
one button mouse *DELETED* | Aussie John | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-03-2007 07:03 PM |
Can I get a three button mouse to work In OS9?????? | el matador | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-04-2003 06:53 AM |
Multi button mouse | jd | Tips & Tricks | 4 | 11-03-1999 05:37 PM |
