Old 10-17-2023, 02:28 AM
danmason danmason is offline
Default Artist Control faders not automating with Protools
Hi, I have an Avid Artist Control and it's been fine in until I came back from an overnight trip where I took my laptop.
I used Protools while away and when I got back and plugged back on the Artist Control faders would move any more.
I can still write automation but the faders are dead otherwise.
Has anyone had this experience?
I've tried putting into test mode and when I push the faders nothing happens. I believe in test mode the fader next to the one you push is supposed to go up.
Any help would be much appreciated!
Old 10-17-2023, 10:28 AM
tope d's Avatar
tope d tope d is offline
Default Re: Artist Control faders not automating with Protools
Hi Dan!
Can you check if your Artist Control is recognizable in your Eucon app on your laptop?
Thanks,
-Tope
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 10-18-2023, 12:35 AM
Hi thanks for your reply. Yes ive checked and it registers in Eucon. It also shows tthe correct screen when in Protools. Its just the faders not automating or moving at all.
They write automation but its like the motors are off. Ive checked if Suspend Motors is checked and its not
Old 10-19-2023, 09:01 AM
EddieJones's Avatar
There are two methods for turning motors off. The setting in EuControl and a softkey for PT only.
Old 10-20-2023, 12:27 AM
Thanks for your message. Would it fail test mode of motors weren't urned off in pt somehow?
Old 03-25-2024, 08:24 PM
keyzone72 keyzone72 is offline
I just noticed the 4 faders on my AVID CONTROL no longer move via the motors from Cubase Pro 13. All the other 16 facers respond via motors for 1 - 16. This is a bummer if they are in fact broken. I had this setup in storage for a while, so I just noticed it today.
Artist Control faders lagging on specific user Digital1 Artist Series 1 03-03-2023 08:52 AM
Artist Control touch screen will not select faders willl3 Artist Series 0 02-02-2017 06:53 PM
Artist Control's Transport and Faders not working with FCP c3kings Artist Series 2 01-20-2015 10:37 AM
Artist Mix - Are faders accurate enough to control plugins? audio.formats Artist Series 4 10-27-2014 03:17 PM
buzzing faders on Artist Control garnoil Artist Series 2 09-03-2012 11:11 AM
