  #21
Old 10-07-2023, 04:00 AM
lonestarparis lonestarparis is offline
Default Re: STRIKE doesn't run anymore
Thank you for the suggestions. I got a tip from AIR too: if I upgrade my Imac to High Sierra I could use these older
https://cdn.inmusicbrands.com/air/x.....0.7_Setup.dmg
https://cdn.inmusicbrands.com/air/x....up.002.dmgpart
If I go for High Sierra, will PT 10.3.7, DIGI 002 console, Vienna Sound Library etc still work?
PT 10.3.7
iMac late 2013
OS X 10.8.5
Digi 002 console
Novation 25 sl mk 2 controller
Focusrite Platinum Voicemaster pro
AKG 451 C matched pair
AKG 414 C XLS matched pair
Sennheiser 406 T matched pair
Mackie HR824 mk2
lots of fine guitars
homestudio, retired guitar teacher, enjoying life and recording
  #22
Old 10-07-2023, 04:37 AM
Hi cvincente22.
Thank you for the ilok temp licence. I tried what you suggested, but still no luck.
(I can't complain, after having recorded without problems for so many years.. and I really don't).
I hope Darryl of jFreak will respond to my question if High Sierra is a good enough upgrade for me, and if they think PT 10.3.7 will still work on it.
PT 10.3.7
iMac late 2013
OS X 10.8.5
Digi 002 console
Mackie HR824 mk2
  #23
Old 10-07-2023, 04:51 AM
JFreak's Avatar
JFreak JFreak is offline
No. Compatibility info here.
Janne
  #24
Old 10-07-2023, 06:01 AM
Hi jFreak,
I did see that list earlier. But does that mean that PT 10.3.7 works only on Mountain Lion? Not on High Sierra?
(Please bare in mind that I'm a good if not great car driver, but a terrible mechanic. That goes for computers too..)
PT 10.3.7
iMac late 2013
OS X 10.8.5
Digi 002 console
Mackie HR824 mk2
  #25
Old 10-07-2023, 06:07 AM
JFreak's Avatar
Yes, that is what it says. For High Sierra you need PT version 12.8.3 thru 2020.12
Janne
  #26
Old 10-07-2023, 07:28 AM
Thank you, jFreak.
Than I'll buy PT 12.8.3.
Will that version only work if one keeps paying for the annual AVID support?
(That was my main reason for staying with 10.3.7, actually.. I'm not a rich pensioner, I'm affraid.)
PT 10.3.7
iMac late 2013
OS X 10.8.5
Digi 002 console
Mackie HR824 mk2
  #27
Old 10-07-2023, 07:33 AM
JFreak's Avatar
With the support plan you get access to all versions since 12.6 until your plan lapses after 12mth of not renewing. The license has a date written into it.
Janne
  #28
Old 10-07-2023, 08:21 AM
(Eh.. trying to get my head around what you say..)
Do you mean that PT 12.8.3 will just stop working when the support plan ends?
So, one is in facto just HIRING PT for as long as one pays for the support?
PT 10.3.7
iMac late 2013
OS X 10.8.5
Digi 002 console
Mackie HR824 mk2
  #29
Old 10-07-2023, 08:30 AM
JFreak's Avatar
No. You get instantly access to versions 12.6 thru current, and after the purchase day any update released within 12mth time. Perpetual license means it will not stop working, but after the date newer versions will not authorize unless you renew the plaan, which gives your license a new date.
Janne
  #30
Old 10-07-2023, 08:31 AM
No that would be a subscription, with a perpetual license support/update plan you get new updates, when the plan expires you stop getting new updates and everything you have up to that date just keeps running. If later you want to update again you can buy another update plan.
My Phoenix II doesn't work anymore mnstudio Pro Tools 1 01-03-2022 02:00 AM
MBox 3 Pro doesn't read anymore tdames FireWire & USB Audio Interfaces (Win) 1 04-20-2015 11:20 AM
itunes doesn't work anymore?!?! ichbin Pro Tools TDM Systems (Mac) 5 01-09-2006 05:38 PM
Midi doesn't work anymore kd_rome MIDI 1 06-24-2004 10:16 AM
Doesn't anybody use Masterlist CD anymore?? Nine Spine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 11-21-2002 11:20 AM
