Old 02-16-2023, 07:02 AM
unkJE's Avatar
unkJE unkJE is offline
Default Getting the Command 8 to work with PT 2022.12 on Win 10 64bit
https://avid.secure.force.com/pkb/ar...nload/en379411
Scroll down to:
Additional Downloads
Legacy Hardware Drivers
download the Command|8 Driver v9.0 for Windows
To install: right-click and select ’Run as administrator
With power off, connect Command 8’s USB cable to computer. Hereafter, always connect Command 8 to this same computer Port
Connect your Keyboard’s MIDI Out to Command 8’s MIDI In
Connect your Keyboard’s MIDI In to Command 8’s MIDI Out
Power-on in this order:
(1) Command 8 (screen will initially read ‘DO NOT TOUCH FADERS’ then ‘Command 8 Offline’
(2) Interface (my Mbox 3 Pro)
(3) Computer with connected music Keyboard (if applicable)
Right-click on Pro Tools Desktop icon>Properties>Run as administrator>OK
Step #1 pic attached:
https://duc.avid.com/attachment.php?...1&d=1676559143
In Pro Tools>Setup>MIDI Input Enable>tick:
Command 8 [Emulated]
MIDI IN 2 (Command 8) [Emulated]
MIDI IN 3 (Command 8) [Emulated]
Step #2 pic attached:
https://duc.avid.com/attachment.php?...1&d=1676559186
Don’t list your Keyboard in Pro Tools Setup>Peripherals
Only list Command 8 in Pro Tools>Setup>Peripherals
Type: Command 8
Receive From: Command 8 [Emulated]
Send To: Command 8 [Emulated]
Step #3 pic attached:
In Pro Tools>Setup>MIDI>MIDI Studio Setup
Under ‘Name’ on LHS, the box is initially blank
Clicking either Windows Snipping Tool, or Pro Tools>Options
will populate ‘Properties’ on the RHS of MIDI Studio Setup
With the 16 Send Channels all in blue and the 16 Receive Channels all in gray, select Command 8 [Emulated] in the Output Port’s drop-down menu
and leave Manufacturer, Model and Input Port set to ‘None’
Save your Pro Tools Session
(Alt + F4) to exit
Restart computer
Launch Pro Tools – when a Session is opened, Command 8 will now read:
Dialog!
Pro Tools has a dialog on screen.
Pro Tools Studio 2024.3 * Studio One Pro 6.6 * Harrison Mixbus 10 Pro * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 & Air 32 MINI * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock * 3 TB Samsung SSDs * 3 Screens: 15.6” Laptop & 24” BENQ LED GL2450-B & Samsung 27” CT550 curved Monitor
Old 01-11-2024, 09:33 AM
moonwalker2 moonwalker2 is offline
Default Re: Getting the Command 8 to work with PT 2022.12 on Win 10 64bit
Do you have the driver available to you? I just went to the Avid website and it seems to have been removed from there. When I click the link I just get an error message. (right-clicking and "save as..." does not work either.)
Old 01-11-2024, 04:55 PM
unkJE's Avatar
Default Re: Getting the Command 8 to work with PT 2023.12 on Win 10 64bit
Command8_Driver_Pro_Tools v90_69592 (Windows) download link:
https://akmedia.digidesign.com/suppo...0v90_69592.zip
PT 2023.12 Updates:
Step #3 - MIDI Studio Setup is not necessary for PT 2023.12
Just Step #1 (MIDI Input Enable) and Step #2 (Peripherals) – Save Session, restart, launch PT, open Session ... then ‘record-arm Track’
My previous Startup order was:
Was experiencing “No Audio” in PT 2023.12, even though it was visible on Tracks and Mixer.
Audible Audio returned after I changed my Startup order to:
(1) Turn computer ON first
(2) Turn on Interface
(3) Turn on Command 8
Last edited by unkJE; 02-12-2024 at 12:27 AM. Reason: changed Startup order - computer ON first (PT2023.12)
Old 01-11-2024, 11:35 PM
Thank you, that worked great!
And a good reminder to save these drivers, Avid won't host them forever...
D-Command with 2022.10 Skwaidu ICON & C|24 7 10-09-2023 10:52 AM
Getting the Command 8 to work with PT9 on Win 7 64bit... Gilesy ProControl, Control|24, Command|8 13 02-15-2023 04:13 AM
What versions of Pro Tools 2022 work with Eucon 2022.9 Mixmaster Rick Pro Tools 2 12-28-2022 01:13 PM
D-Command with 2022.4 Third Eye Studios ICON & C|24 14 05-06-2022 08:29 PM
protools 8.0.5 NOT WORK ON WINDOWS SEVEN 64bit markolone Pro Tools M-Powered (Win) 8 04-30-2011 02:07 AM
