Spark
I have so far been unable to import an audio file from 001 onto TC Spark.
Is there a trick to this?? |
Re: Spark
sorry...RTFM
Re: Spark
Before bouncing your files to HD you have to convert them into the right format!
Choose *.wav and it runs.... DigiG4 |
Re: Spark
Walter,
I tried opening a PT file from within Spark 1.0 by using the "open" command - it opened up just fine. No conversion was required. Jeff D. |
Re: Spark
hello,
can any of you tell me if you got spark running simulatneously with pt5le/001? I would like to never leave the protools environment, (shut down) to use spark... |
Re: Spark
one way to do it is to run spark through sound manager, and pt through the digi001.....another way is to route spark's output through direct connect (you need the 1.1 beta, though)...both these set-ups worked for me.........
Re: Spark
domsound,
Try disabling Active In Background under the Operations pulldown menu. This way DAE will release the hardware when PTLE is in the background so other apps may use it. Brent |
Electricity/Spark SFX | spigots | Post - Surround - Video | 5 | 03-09-2004 09:11 AM |
Spark 2.8XL or Peak 3.2 | bopsi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-06-2003 11:03 AM |
SPARK XL 2.5 | mongokongo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-11-2002 01:27 PM |
Spark xl - AMIII | Nils M | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-01-2002 08:27 AM |
Spark and digi 001 | billrog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 11-05-2000 02:35 PM |
