PT 10.3.7 HD error setting up O/I Paths Bus 127-128
hi all i working with PT 10.3.7 HD(is amazing DAW with many options) but one day show me error: setting up O/I Paths Bus 127-128 any ideas can fix this error
SiSoftware Sandra ID Host Name : P******** Workgroup : WORKGROUP Computer Model : Dell Inspiron N5110 Serial Number : 4X8**** Chassis : Dell Portable Mainboard : Dell 0HVRTT Serial Number : .4X8GKP1.CN7************ BIOS : Dell A11 08/03/2012 Intel vPro : 7.00.04.1197 Total Memory : 5.92GB DDR3 SO-DIMM Processors Processor : Intel(R) Core(TM) i7-2630QM CPU @ 2.00GHz (4C 8T 2.6GHz/2.9GHz, 2.6GHz IMC, 4x 256kB L2, 6MB L3) Socket/Slot : FC PGA988 Chipset Memory Controller : Dell Core (Sandy Bridge) Mobile DRAM Controller 100MHz, 2x 3GB DDR3 SO-DIMM 1.33GHz 128-bit, Integrated Graphics Memory Module(s) Memory Module : Nanya NT2GC64B88B0NS-CG 2GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Samsung M471B5273CH0-CH9 4GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5) Video System Monitor/Panel : CMO Generic PnP Monitor (1600x1200, XM5XGN156B6 , 15.3") Video Adapter : Intel(R) HD Graphics Family (12CU 60SP SM4.1 650MHz/1.1GHz, 64MB DDR3 1.33GHz 128-bit, Integrated Graphics) Graphics Processor OpenCL GP Processor : NVIDIA GeForce GT 525M (96SP 2C 1.19GHz, 128kB L2, 1GB 1.79GHz 128-bit) Compute Shader Processor : Intel(R) HD Graphics Family (60SP 12C 650MHz/1.1GHz, 64MB DDR3 1.33GHz 128-bit, Integrated Graphics) Compute Shader Processor : NVIDIA GeForce GT 525M (96SP 2C 1.19GHz, 128kB L2, 1GB 1.79GHz 128-bit) CUDA GP Processor : NVIDIA GeForce GT 525M (96SP 2C 1.19GHz, 128kB L2, 1GB 1.79GHz 128-bit) Storage Devices TOSHIBA MK6475GSX (640.1GB, SATA300, 2.5", 5400rpm, 8MB Cache) : 596GB (C:) (D:) Generic- Multi-Card (USB2) : N/A (E:) PLDS DVD+/-RW DS-8A5SH (SATA150, DVD+-RW, CD-RW) : N/A (F:) DTSOFT BDROM (2.6GB, ) : 2GB (G:) Logical Storage Devices System Reserved : 100MB (NTFS) Hard Disk (C:) : 147GB (NTFS) @ TOSHIBA MK6475GSX (640.1GB, SATA300, 2.5", 5400rpm, 8MB Cache) Disk 2 (D:) : 449GB (NTFS) @ TOSHIBA MK6475GSX (640.1GB, SATA300, 2.5", 5400rpm, 8MB Cache) Removable Drive (E:) : N/A @ Generic- Multi-Card (USB2) Optical Drive (F:) : N/A @ PLDS DVD+/-RW DS-8A5SH (SATA150, DVD+-RW, CD-RW) Disc (G:) : 2GB (UDF) @ DTSOFT BDROM (2.6GB, ) Peripherals LPC Hub Controller 1 : Dell HM67 LPC Controller LPC Legacy Controller 1 : Winbond WPCE775LA Audio Device : Dell Cougar Point High Definition Audio Controller Audio Codec : Integrated Device Tech 76D1 Disk Controller : Dell Cougar Point Mobile 6 port SATA AHCI Controller USB Controller 1 : Dell Cougar Point USB Enhanced Host Controller #2 USB Controller 2 : Dell Cougar Point USB Enhanced Host Controller #1 USB Controller 3 : Dell Renesas Electronics USB 3.0 Host Controller SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer v4 (600x600, Colour) Printer : Journal Note Writer Driver (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Realtek PCIe FE Family Controller (Ethernet) Network Adapter : Bluetooth Device (Personal Area Network) (Ethernet) Network Adapter : TAP-Windows Adapter V9 (Ethernet) Network Adapter : TAP-Win32 Adapter OAS (Ethernet, 10Mbps) Network Adapter : TAP-Windows Adapter V9 #2 (Ethernet, 10Mbps) Network Adapter : TAP-Win32 Adapter OAS #2 (Ethernet, 10Mbps) Wireless Adapter : Intel(R) Centrino(R) Wireless-N 1030 (802.11n (HT), AES-CCMP, 72Mbps) Power Management Battery No 1 : SMP DELL 8NH5516 3.56Wh/0.29Ah Operating System Windows System : Microsoft Windows 8.1 Home 6.03.9600 Platform Compliance : x64 Windows Experience Index Current System : 5.4 |
Re: PT 10.3.7 HD error setting up O/I Paths Bus 127-128
May be unrelated, but from your SANDRA it looks like you have mismatched RAM - 2GB and 4GB. It's recommended to have identical sticks of memory for the best performance. Also, your hard drives appear to be only 5400 rpm and you really need at least 7200, or an external or 2nd drive for audio that runs at least 7200 rpm.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
ok, i understand my error in RAM and HDD, but i work with PT around two month without errors...
Have you gone to the I/O Setup and hit default? Oftentimes that fixes things.
actually give me an error message, after Pro Tools loading DAE
Again, What is the exact error message?
error setting up O/I Paths Bus 127-128 one option i have to close PT
Did you try deleting preferences and databases?
ok i cleaning my PC from many errors and now PT work perfect thanks for big help :)
Stalls on startup - Setting up I/O paths... | jakorsme | Windows | 46 | 08-05-2014 09:37 AM |
Pro Tools 10.3.8 hangs at "Setting up I/O paths... Analog 1-2" [RESOLVED] | spmusik | Pro Tools 10 | 15 | 06-03-2014 07:22 PM |
Pro Tools Crashes on Startup During "Setting Up I/O Paths" | ChrisIQ | Pro Tools 10 | 3 | 08-24-2013 05:27 PM |
Question about Sub Paths and Main paths. | oulablank | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-15-2009 12:15 PM |
hardware setting error | doyle204 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-11-2002 02:59 PM |
