Old 05-01-2014, 06:44 PM
spmusik spmusik is offline
Default Pro Tools 10.3.8 hangs at "Setting up I/O paths... Analog 1-2" [RESOLVED]
Just installed a new Mac Pro 6,1 6-core, and no major issues, but when loading the splash screen/plugs/etc, it hangs on the last step, setting up the I/O paths. I can run sessions, but waiting 5 minutes at that point every time I start Pro Tools is beyond annoying- I'm sure you can all relate. Was never an issue before the new Mac and Mavericks. I've done all the things usually expected to solve an issue like this- trashing prefs, setting default I/Os, etc.. but nothing is fixing it. Has anyone else encountered this issue?
Thanks!
Old 05-01-2014, 08:03 PM
Default Re: Pro Tools 10.3.8 hangs at "Setting up I/O paths... Analog 1-2"
Or does anyone have any ideas how to alleviate this issue.. much appreciated!
Old 05-02-2014, 09:10 AM
No one? I didn't get this speedy new computer to have to wait an extra 5 minutes at startup... clearly not everyone is experiencing it, so there has to be an answer.
Old 05-05-2014, 03:11 PM
Question Re: Pro Tools 10.3.8 hangs at "Setting up I/O paths... Analog 1-2"
What is your playback engine setting? Hold the "n" key during startup.
Old 05-23-2014, 02:34 AM
Output is going to my 003
H/W Buffer size = 128
Host Processors = 11 of 12 (6 Core Mac Pro)
CPU Limit: 99%
Host Engine Ignores errors, Delay Comp off.
Is there something I should be doing differently? Thanks for any info, sorry for the late reply!
Old 05-23-2014, 02:38 AM
Could it be related to my SSD? Was reading another thread pertaining to that (although it was Windows-based)
Old 05-23-2014, 04:07 AM
JFreak's Avatar
JFreak JFreak is online now
I think it's related to the fact that the new iTrashcans must use Mavericks and PT10 is only supported up to Mountain Lion
Janne
Old 05-23-2014, 08:54 AM
But I feel like reports of this would be more widespread then- I see very few people complaining about this issue, and I'm sure there are a number of folks running Mavericks + Pro Tools 10...
Old 05-23-2014, 10:02 AM
JFreak's Avatar
Lots of people have success with Mav+PT10 but Avid does not support the configuration. Effectively, it means you can try but cannot blame Avid if you don't succeed...
Janne
Old 05-23-2014, 10:57 AM
True, and that's understood- it's not like my system *doesn't work*, I'm just now stuck with an absolutely HORRENDOUS load time of around 6-7 minutes, and looking for helpful information, suggestions, or a solution..
Stalls on startup - Setting up I/O paths... jakorsme Windows 46 08-05-2014 09:37 AM
Pro Tools Crashes on Startup During "Setting Up I/O Paths" ChrisIQ Pro Tools 10 3 08-24-2013 05:27 PM
Pro Tools 9 Hangs "Setting up MIDI" FranklynJones Windows 8 12-19-2011 02:21 PM
Pro Tools le 6.0 (and 6.0.1) hangs on "setting up Midi"-- then unexpectedly quits rdatman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-19-2010 09:15 PM
setting up an analog studio with pro tools? sethbrand Tips & Tricks 9 03-31-2007 03:06 PM
