Pro Tools Crashes on Startup During "Setting Up I/O Paths"
Completely new user to Pro Tools. Installed it, got everything up and running just fine and was recording and bouncing with no issues. Two days later when I went to run the program I was hit with "Pro Tools Application Has Stopped Working", which happens when the loading gets to the "Setting Up I/O Paths" in the process, and when this happens it's always showing "Bus 31-32" as the moment that the program is crashing during startup.
I uninstalled and reinstalled everything. Worked fine for two days, now the literal exact same issue is happening, all the way down to it saying "Setting Up I/O Paths, Bus 31-32" at the moment of the crash. Any suggestions? I unfortunately do not know the hardware nearly well enough to try to attempt a fix, especially since I can't even get the program to fully load now. Details: Pro Tools Versions: 10.3.5 Computer: Windows 7 64-bit Operating System |
Re: Pro Tools Crashes on Startup During "Setting Up I/O Paths"
Try holding "N" while starting Pro Tools and see if it gets you in to double check the audio device, and perhaps reset the IO to defaults:
http://logicprotools.wordpress.com/2...own-the-n-key/ Joel
Jam Space: HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Rig: Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM |
I'll try that tonight, thanks! Would appreciate any other suggestions
Thank you!
I wasn't quite having the same issue, but this same answer solved it! |
Pro Tools Crashes during "Restoring Tracks" portion of startup | rhythmator | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 12-28-2014 10:42 AM |
PT startup stalls at "setting up peripherals" | Eric L | Post - Surround - Video | 3 | 03-14-2012 12:07 PM |
Pro tools 9 crashes at startup "Bus error" in thread "MainThread", at address 0x0 | danball | macOS | 2 | 09-26-2011 04:49 PM |
BSOD on Startup - freezes when "Setting up MIDI" | jervo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 08-22-2010 11:35 AM |
Opinions re: Dual "Startup Disks" or "Extension Sets"? | accession | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 06-29-2001 10:56 PM |
