Old 05-26-2011, 04:14 AM
Abassi Abassi is offline
Default usb not working on Venue profile
hello, I need your help, my console digidesign Venue profile; all usb interface control no longer works and 2 usb FOH Rack is operating normally. I checked the cables, reinstall the software but nothing has changed
Old 05-26-2011, 05:05 AM
Audioartist Audioartist is offline
Default Re: usb not working on Venue profile
It´s probably the digilink cable between the rack and console.
I have the same problem from time to time.
The screen can also be a little wierd, with colours missing.
I wish they would do something about those cables, a little better quality for the price.
Old 05-26-2011, 05:30 AM
mariojorgeandrade mariojorgeandrade is offline
It happened once to me.
The USB and headphone outputs on the Profile surface weren't working.
Later, I found out that was only because someone hadn't connected the
umbilical cable from the Mixrack to the Profile surface tightly enough.
Only that.
Never happened again.
Maybe you're having the same problem, check it out.
Good luck.
Regards,
MJ
Old 05-26-2011, 08:52 AM
Sheldon Radford's Avatar
Sheldon Radford Sheldon Radford is offline
COntact the support team, they can help troubleshoot this.
+1 650 731 6111 or venuesupport(at)avid(dot)com
Sheldon
FX Routing ON Venue Profile PKPMusic VENUE Live Sound Systems 2 07-28-2012 08:23 AM
Is Venue Profile good enough ? deardaddy VENUE Live Sound Systems 8 02-12-2012 08:46 AM
Venue D Show vs Venue Profile [email protected] VENUE Live Sound Systems 14 07-06-2011 02:31 PM
VENUE Profile, max. channels - 96 or 128? kwz VENUE Live Sound Systems 3 12-16-2010 11:15 PM
Midi and Venue Profile jxgriffi MIDI 3 03-02-2008 03:31 PM
