Stuck in custom fader mode on D-Con?
16 channel D-Con. I don't have any custom fader mode selected, but the first 8 faders are stuck in CF mode with the blue lights. I see plugin parameters on the encoders. If I actually select plug-in CF mode, then the parameters show up on both sets of 8 encoders.
When the session opens, for a split second, the faders are all populated and then it snaps to only having 8 faders active in normal mode. Any ideas? I've poked around in the manual and tried searches but haven't been able to find anything yet. I've tried resetting the icon, rebooting, etc. to no avail. Thanks for any help!
--Inaam |
Re: Stuck in custom fader mode on D-Con?
did you try remove D-Control from PT and re-declare it?
Mix Stage 1 PT HDX Ultimate 2022.12 D-Control HD I/O Hackintosh i9 12900K 32 Gb RAM OSX 12.6.7 Mix Stage 2 PT HDX2 Ultimate 2023.6 S6 MTRX I/O Hackintosh i7 8700K 32 Gb RAM OSX 12.6.7 Mix Stage 3 PT HDX Ultimate 2023.6 D-Command HD I/O Hackintosh i7 8700K 32 Gb RAM OSX 12.6.7 ADR PT MBox Studio Ultimate 2023 Mac Mini M1 8 Gb RAM OSX 13.4.1 Edit 1 PT HDN PCIe 2023.6 96 I/O Intel i7 6700K 32 Gb RAM.OS Windows 10 Estúdio JLS Facilidades Sonoras São Paulo - Brazil |
Thanks for replying. Yes, I did that too!
Any other ideas?
--Inaam |
maybe a bad cable connection? I don't know if you can do it, but, did you try to install D-Control on a "older" PT, like 7.1? I'm telling you this because, this can be a firmware problem, and doing this you force D-Control to update its current firmware.
Thanks. I checked the firmware version on the ICON and it was 7.X, so I updated to the current firmware version 8.0.0.314, and still no joy!
--Inaam |
Well, in addition to the original firmware update, I did a firmware reset and subsequent update as described in the link, and there was still no change.
I tried toggling the LCF PI pref value and that seems to have kicked things back into shape! Thanks to all for your responses!
--Inaam |
D-Command Master fader stuck in Inserts mode | Jambroch | ICON & C|24 | 2 | 12-17-2012 12:23 PM |
Max Custom Fader Bank | JKD99 | ICON & C|24 | 6 | 11-23-2009 09:27 AM |
volume fader in custom fader mode | KimSira | ICON & C|24 | 4 | 10-15-2008 09:54 PM |
No Fader Flip In Custom Fader Mode? | GlennR01 | ICON & C|24 | 13 | 05-29-2007 04:40 PM |
Custom Fader Mode on D-Command (TURN OFF) | EvanScottSmith | ICON & C|24 | 1 | 01-31-2007 04:07 PM |
