Old 10-02-2009, 05:50 AM
03studio 03studio is offline
Exclamation Pro Tools HD 2 Accel Aux and Master Bug !!! Important
I`ve a new HD 2 Accel PCIe with Pro Tools 8.01. on my G5 Quad with 10.5.8. Combo. + UAD Quad PCIe
The Problem is:
When i put a Plugin into an AUX Or Master Buss, the whole channel distortions!!!
And if i use Logic Pro 9 with the Pro Tools DTDM it`s the same problem!
Perhaps the Core is damage??! Anyone any ideas?
I wrote Digidesign Support a lot of mails since a few days, but didn`t get any ansswer ;-(
Old 10-02-2009, 07:18 AM
dbjp dbjp is offline
Default Re: Pro Tools HD 2 Accel Aux and Master Bug !!! Important
Does the same thing happen if you pull the UAD card out and take those plugins out of the plugin folder?
Old 10-02-2009, 07:34 AM
crizdee's Avatar
crizdee crizdee is offline
Originally Posted by 03studio View Post
The Problem is:
Which plugins? or is it any plugin? RTAS OR TDM?
What level are all your faders at?
What audio source are you using?
Whats your hardware buffer set to?
Chris
Producer, Engineer,
www.ukmastering.com
Old 10-02-2009, 09:26 AM
sometime rtas or TDM Pluins make this misstake...
Level normal 0db... but it distortion on every kind of level...;-(
UAD Card out of the mac takes the same failure...
Old 10-02-2009, 09:30 AM
and the main thing i`m wondering... i had a hd 3 in this before without any stress...
perhaps the UAD 2 Card..?..but i don`t use any uad Plugins when the system distores...
Old 10-02-2009, 10:20 AM
crizdee's Avatar
have you run Digi test? its in the digi folder /applications
could be card or flex cable, test with just the core card!!
Chris
Producer, Engineer,
www.ukmastering.com
Old 10-02-2009, 11:42 AM
digitest is o.k.
digilink cable and 96 i/o change but nothinmg happens
flexcable is checked...
i will check it without 1 accel card
Thanks
Old 10-02-2009, 11:49 AM
Try it with the UAD plugins taken out of your plugin folder. Make sure all other plugins are up-to-date.
Old 10-02-2009, 02:46 PM
ssooooooo...
i built out the accel card... and now i works perfect!!!
Thanks for support!!
Old 10-02-2009, 03:46 PM
crizdee's Avatar
ssooooooo...
Could be the accel card or more likely the flex cable? see if you can get another flex cable to try. or buy one from the Digi store
Chris
Producer, Engineer,
www.ukmastering.com
More important: Standalone App or Pro Tools window? TheChimp Eleven Rack 45 11-29-2012 11:16 PM
IMPORTANT: Pro Tools 6.4.1 for MAC Needed Brahamnesik Digidesign Hardware & Software 9 10-17-2011 02:04 PM
Important equipment - real important netnoggin General Discussion 14 05-14-2010 02:05 PM
Pro Tools LE Startup Problem!!IMPORTANT!! s03306 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-28-2009 03:05 AM
TC Works MASTER X3 & TC Tools v3.7 for Accel Avid General 0 12-09-2003 06:49 PM
